I'm trying to disable REPL on UART 0 on my NodeMCU V3 and use it for sensor communication, but cannot receive any characters as `UART.any()` always returns zero. I'm able to write to UART and send the data to the sensor side, but still can not read from it.
At one time, as I suspected, seen that the data is trapped in the buffer of REPL, even though it is disabled. That was revealed due to some kind of exception and I can't remember how that had happened.
I'm using stock boot.py but would like to paste here to clear any doubts.
boot.py:
# This file is executed on every boot (including wake-boot from deepsleep)
#import esp
#esp.osdebug(None)
import uos, machine
#uos.dupterm(None, 1) # disable REPL on UART(0)
import gc
#import webrepl
#webrepl.start()
gc.collect()
import esp
import uos
from sys import exit
is_led_on = True
led = machine.Pin(2, machine.Pin.OUT) # Built-in LED
bypass_pin = machine.Pin(5, mode = machine.Pin.IN, pull = machine.Pin.PULL_UP)
except:
exit()
if bypass_pin.value() == 0:
print("Bypass activated. Quitting main.py...")
for i in range(5):
time.sleep(0.1)
led.on()
time.sleep(0.1)
led.off()
time.sleep(1)
led.on()
exit()
def finish_execution():
print("Finishing app execution.")
uos.dupterm(machine.UART(0, 115200), 1) # Move REPL to its original place
exit()
uos.dupterm(machine.UART(1, 115200), 1) # Move REPL to UART1 to see the outputs
print("App started.")
class SerialDevice:
Serial device management class
def __init__(self):
self.rx_buffer = bytearray(2048)
self.rx_vector = 0
self.waited_for_eof = False
self.read_data_len = None
self.port = machine.UART(0, 115200)
self.port.init(115200, bits=8, parity=None, stop=1)
print("Serial device serial port enabled.")
except Exception as e:
print("Cannot enable serial device port.")
print(e)
finish_execution()
def receive_data(self) -> bool:
print("UART Rx Check")
data_amount = self.port.any()
if data_amount != 0:
self.read_data_len = self.port.readinto(memoryview(self.rx_buffer)[self.rx_vector:], len(self.rx_buffer) - self.rx_vector)
except OSError as e:
print(("Serialport OsError ({error})").format(error=e.strerror))
return False
print("Unhandled exception while reading port")
print(e)
return False
if self.read_data_len is None:
if self.rx_vector != 0:
if self.waited_for_eof == True:
return True
self.waited_for_eof = True
return False
return False
self.rx_vector += self.read_data_len
print(("Port data received ({read_data_amount})").format(read_data_amount=self.read_data_len))
return False
def clear_rx_buffer(self):
self.rx_vector = 0
serial_dev = SerialDevice()
print("Error: Serial device configuration error.")
print(e)
finish_execution()
if serial_dev.receive_data():
serial_dev.port.write(memoryview(serial_dev.rx_buffer)[:serial_dev.rx_vector])
serial_dev.clear_rx_buffer()
time.sleep(1) # Extreme delay for debug purposes. Will be 0.1 for production.
Thanks in advance for your any kind of help.
Cheers,
/// Murat
