Cannot use UART0 for sensor communication
MuratUrsavas
Post by MuratUrsavas » Thu Jul 07, 2022 9:16 pm
I'm trying to disable REPL on UART 0 on my NodeMCU V3 and use it for sensor communication, but cannot receive any characters as `UART.any()` always returns zero. I'm able to write to UART and send the data to the sensor side, but still can not read from it.
At one time, as I suspected, seen that the data is trapped in the buffer of REPL, even though it is disabled. That was revealed due to some kind of exception and I can't remember how that had happened.
I'm using stock boot.py but would like to paste here to clear any doubts.
boot.py:
# This file is executed on every boot (including wake-boot from deepsleep)
#import esp
#esp.osdebug(None)
import uos, machine
#uos.dupterm(None, 1) # disable REPL on UART(0)
import gc
#import webrepl
#webrepl.start()
gc.collect()
main.py:
import esp
import uos
from sys import exit
is_led_on = True
led = machine.Pin(2, machine.Pin.OUT)        # Built-in LED
    bypass_pin = machine.Pin(5, mode = machine.Pin.IN, pull = machine.Pin.PULL_UP)
except:
    exit()
if bypass_pin.value() == 0:
    print("Bypass activated. Quitting main.py...")
    for i in range(5):
        time.sleep(0.1)
        led.on()
        time.sleep(0.1)
        led.off()
    time.sleep(1)
    led.on()
    exit()
def finish_execution():
    print("Finishing app execution.")
    uos.dupterm(machine.UART(0, 115200), 1)         # Move REPL to its original place
    exit()
uos.dupterm(machine.UART(1, 115200), 1)     # Move REPL to UART1 to see the outputs
print("App started.")
class SerialDevice:
    Serial device management class
    def __init__(self):
        self.rx_buffer = bytearray(2048)
        self.rx_vector = 0
        self.waited_for_eof = False
        self.read_data_len = None
            self.port = machine.UART(0, 115200)
            self.port.init(115200, bits=8, parity=None, stop=1)
            print("Serial device serial port enabled.")
        except Exception as e:
            print("Cannot enable serial device port.")
            print(e)
            finish_execution()
    def receive_data(self) -> bool:
        print("UART Rx Check")
            data_amount = self.port.any()
            if data_amount != 0:
                self.read_data_len = self.port.readinto(memoryview(self.rx_buffer)[self.rx_vector:], len(self.rx_buffer) - self.rx_vector)
        except OSError as e:
            print(("Serialport OsError ({error})").format(error=e.strerror))
            return False
            print("Unhandled exception while reading port")
            print(e)
            return False
        if self.read_data_len is None:
            if self.rx_vector != 0:
                if self.waited_for_eof == True:
                    return True
                    self.waited_for_eof = True
                    return False
                return False
        self.rx_vector += self.read_data_len
        print(("Port data received ({read_data_amount})").format(read_data_amount=self.read_data_len))
        return False
    def clear_rx_buffer(self):
        self.rx_vector = 0
    serial_dev = SerialDevice()
    print("Error: Serial device configuration error.")
    print(e)
    finish_execution()
    if serial_dev.receive_data():
        serial_dev.port.write(memoryview(serial_dev.rx_buffer)[:serial_dev.rx_vector])
        serial_dev.clear_rx_buffer()
    time.sleep(1)       # Extreme delay for debug purposes. Will be 0.1 for production.
To simplify reproduction, I've removed almost all unrelated logic and just added a simple echo to the same UART.
Thanks in advance for your any kind of help.
Cheers,
/// Murat
Re: Cannot use UART0 for sensor communication
Post by jimmo » Fri Jul 08, 2022 6:28 am
Off the top of my head my guess would be that your NodeMCU board has the USB/UART adaptor connected to UART 0, and this is always holding the UART RX pin low.
MuratUrsavas
Post by MuratUrsavas » Fri Jul 08, 2022 6:43 am
Thanks for your response @jimmo. Yes, I'm aware of that and just using the same channel (/dev/ttyUSB0) for my tests. So it's OK to use it for now. And I've verified the RX pin is acting correctly, showing the correct incoming characters electrically. So the actual problem is, somehow I can not reach the received characters in software.
The thing you've mentioned is a worry about the production. That could be my followup question. What's the best way to move it another location which would not be interfered by the installed USB - UART converter?
I'm also suspecting from REPL placement to UART1. As it actually only has TX line, RX line could be kept at the UART 0 RX location and since REPL is not active while my app is running, it could be kept in the buffer untouched. This is not something I've verified, though.
Post by jimmo » Mon Jul 11, 2022 5:49 am
The ESP8266 UART is pretty limited. You can either have it on pins 1 & 3 or 15 & 13.
Like you say there is only one UART (the second only has TX available).
As long as you have your USB/UART converter connected to pins 1 & 3, you will be unable to use those pins for anything else.
MuratUrsavas
Post by MuratUrsavas » Thu Jul 14, 2022 7:29 am
Somehow I've been stuck even with moving the UART0 to its second location (Pins 13, 15). So I should be doing something fundamentally wrong. Wondering what that is.
