time.ticks_ms overflow
zipdots
Post by zipdots » Mon Jul 25, 2022 2:08 am
Hello!
I recently started learning micropython and I apologize in advance for the question I want to ask, as I understand that most likely the answer to it has already been given, but I could not find it :(
Tell me, what is the maximum value that ticks_ms can return, what happens when it overflows, and what does the term "rollover" mean?
I make a mqtt listener and to maintain a connection with the server I use the ping method so that the server does not disconnect me:
def _mqtt_keepalive_ping(self):
    time_since_last_ping = time.ticks_diff(time.ticks_ms(), self._mqtt_last_ping) // 1000
    if time_since_last_ping >= self._mqtt_client.keepalive:
            self._mqtt_client.ping()
        except OSError:
            self._mqtt_connected = False
            self._mqtt_last_ping = time.ticks_ms()
My method works but I don't know what will happen in the long run.
Online
Re: time.ticks_ms overflow
Post by Roberthh » Mon Jul 25, 2022 5:25 am
The period is 2**30 ms, which is about 298 days. Rollover means, that the value will change from 2**30 -1 to 0. ticks_diff() caters for the rollover and will always return the proper value, unless the time difference is larger than the period of ~298 days.
jomas
Post by jomas » Mon Jul 25, 2022 7:47 am
It is ~298 Hours. Not days.
Online
Post by Roberthh » Mon Jul 25, 2022 8:02 am
right
but that's still a long time.
Post by pythoncoder » Mon Jul 25, 2022 10:42 am
Unless you do some special arithmetic it's 298/2 hours. If you perform a modular arithmetic subtraction of t2 - t1 the result may be positive or negative, depending on whether t2 follows or precedes t1. So the result from ticks_diff(t2, t1) may be +- 298/2 hours. This is explained in the docs.
zipdots
Post by zipdots » Mon Jul 25, 2022 5:11 pm
Thanks for your help!
I did not fully understand what would happen if, after overflowing time.ticks_ms() returned a value less than the one we stored. I ran a small loop and made sure that time._ticks_diff() really detects rollover correctly:
start_time = time.ticks_us()
    current_time = time.ticks_us()
    time_diff = time.ticks_diff(current_time, start_time)
    if time_diff > 100000:
        print(f'Start time {start_time:10d} | Current time {current_time:10d} | Time diff {time_diff}')
        start_time = current_time
Start time 1073425486 | Current time 1073525559 | Time diff 100073
Start time 1073525559 | Current time 1073625628 | Time diff 100069
Start time 1073625628 | Current time 1073726096 | Time diff 100468
Start time 1073726096 | Current time      84284 | Time diff 100012 <---
Start time      84284 | Current time     184337 | Time diff 100053
Start time     184337 | Current time     284397 | Time diff 100060
Start time     284397 | Current time     384438 | Time diff 100041
Thanks again for your answers!
