ets Jan 8 2013,rst cause:4, boot mode:(3,7)
Posted: Sun Aug 07, 2022 1:36 pm
Good afternoon,
This error persists in my code, from what I have been searching on the internet, it could be network connection problems but I have also seen problems with power supply, pin without time sleep and so on.
wdt reset
load 0x40100000, len 30720, room 16
tail 0
chksum 0xba
load 0x3ffe8000, len 996, room 8
tail 12
chksum 0x2c
ho 0 tail 12 room 4
load 0x3ffe83f0, len 1080, room 12
tail 12
chksum 0x43
csum 0x43
I really don't know what to do or how to solve this.
I provided my github repository to analyze all the code, but what is failing is the main.py file
https://github.com/4kasmouton/esp8266-smart-terrarium
import usocket as socket
except:
import socket
import dht
from machine import Pin, I2C, SoftI2C, WDT
from lcd_api import LcdApi
from i2c_lcd import I2cLcd
import socket as s
import gettime
import esp
esp.osdebug(None)
import gc
gc.collect()
def temperature(d):
d.measure()
time.sleep(1)
return d.temperature(), d.humidity()
def web_page(TEMPSTATE, HUMSTATE, UVLIGTH,HOTSPOT,NIGTHHOT):
#print(TEMPSTATE, HUMSTATE, UVLIGTH,HOTSPOT,NIGTHHOT)
html = """<html><head> <title>ESP Web Server</title> <meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="icon" href="data:,"> <style>html{font-family: Helvetica; display:inline-block; margin: 0px auto; text-align: center;}
h1{color: #0F3376; padding: 2vh;}p{font-size: 1.5rem;}.button{display: inline-block; background-color: #e7bd3b; border: none;
border-radius: 4px; color: white; padding: 16px 40px; text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}
.button2{background-color: #4286f4;}</style></head><body><h1>ESP Web Server</h1>
<p>Temperatura: <strong>"""+ str(TEMPSTATE) + """</strong></p>
<p>humidade: <strong>""" + str(HUMSTATE) + """</strong></p><p>LUZ UV: <strong>""" + UVLIGTH + """</strong></p>
<p>LUZ AQUECIMENTO: <strong>""" + HOTSPOT + """</strong></p><p>LUZ Noturna: <strong>""" + NIGTHHOT + """</strong></p>"""
return html
def wificonnect():
ssid = 'MEO-43253f4'
password = '*******'
station = network.WLAN(network.STA_IF)
station.active(True)
station.connect(ssid, password)
while station.isconnected() == False:
pass
return station.ifconfig()
def controlerligthUV(hour,UVB):
if 8 <= hour <= 19:
print("dia")
UVB.value(1)
time.sleep(2)
return "on"
print("noite")
UVB.value(0)
time.sleep(2)
return "off"
def controlerligthhot(temp,ligthhot, hour):
if 8 <= hour <= 19:
if temp >= 27:
print("desliga a luz de calor")
ligthhot.value(0)#desliga a luz
time.sleep(2)
return "off"
print("liga a luz de calor")
ligthhot.value(1)#liga a luz
time.sleep(2)
return "on"
return "off"
def nigthhot(hour, temp,ligthnigthhot):
if 8 <= hour <= 19:
if temp <= 18:
print("liga a luz de calor noturna")
ligthnigthhot.value(1)#liga a luz
time.sleep(2)
return "on"
print("esta dentro desta hora")
return "off"
ligthnigthhot.value(0)
time.sleep(2)
return "off"
def watercontroler(hour,minu,waterpin):
if hour == 8:
if 30 <= minu <= 34:
print("entrou 1")
waterpin.value(1)
time.sleep(15)
waterpin.value(0)
time.sleep(300)
elif hour == 12 :
print("entrou 2")
waterpin.value(1)
time.sleep(15)
waterpin.value(0)
time.sleep(300)
elif hour == 15:
print("entrou 3")
waterpin.value(1)
time.sleep(15)
waterpin.value(0)
time.sleep(300)
elif hour == 18:
print("entrou 4")
waterpin.value(1)
time.sleep(15)
waterpin.value(0)
time.sleep(300)
print("nao precisa regar")
#defenir lcd
I2C_ADDR = 0x27
totalRows = 2
totalColumns = 16
#led = Pin(2, Pin.OUT)
i2c = I2C(scl=Pin(5), sda=Pin(4), freq=10000)
lcd = I2cLcd(i2c, I2C_ADDR, totalRows, totalColumns)
#Definir o sensor de temperatura
d = dht.DHT11(Pin(16))
#connectar a internet e definir o socket
IP=wificonnect()
led = Pin(2, Pin.OUT) #led da board
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.bind((IP[0], 801))
s.settimeout(10)
s.listen(1)
waterpin=led = Pin(15, Pin.OUT)
waterpin.value(0)
UVB = Pin(13, Pin.OUT)
UVB.value(0)
ligthhot=Pin(12, Pin.OUT)
ligthhot.value(0)
ligthnigthhot=Pin(14, Pin.OUT)
temp,hum=temperature(d)
UVLIGTH="off"
HOTSPOT="off"
NIGTHHOT="off"
gc.collect()
print("testrede1")
lcd.clear()
lcd.putstr(IP[0])
print("testrede1")
conn, addr = s.accept()
time.sleep(1)
print('Got a connection from %s' % str(addr))
conn.settimeout(3)
request = conn.recv(1024)
request = str(request)
print('Content = %s' % request)
response = web_page(temp,hum,UVLIGTH,HOTSPOT,NIGTHHOT)
conn.send(b'HTTP/1.1 200 OK\n')
conn.send(b'Content-Type: text/html\n')
conn.send(b'Connection: close\n\n')
conn.sendall(response.encode())
conn.close()
print("connecção")
s.settimeout(5)
lcd.clear()
except:
print("hora")
hora =gettime.gettime()
print("UVLIGTH")
UVLIGTH =controlerligthUV(hora[3],UVB)
lcd.clear()
phrase="Temp:"+str(temp)+" Hum:"+str(hum)+"%"
lcd.putstr(phrase)
print(temp,hum)
print("HOTSPOT")
HOTSPOT = controlerligthhot(temp,ligthhot,hora[3])
print("NIGTHHOT")
NIGTHHOT = nigthhot(hora[3], temp,ligthnigthhot)
print("watercontroler")
watercontroler(hora[3],hora[4],waterpin)
time.sleep(5)
print("test1")
lcd.clear()
lcd.putstr(IP[0])
time.sleep(2)
print("test2")
lcd.clear()
lcd.putstr(phrase)
lcd.clear()
print(hora)#printa o tempo atualizado
times = str(hora[0])+"-"+str(hora[1])+"-"+str(hora[2])+" "+str(hora[3])+":"+str(hora[4])+":"+str(hora[5])
print("test3")
lcd.putstr(times)
time.sleep(5)
print("test4")
except Exception as e:
#lcd.putstr(str(e))
print(e)
#lcd.putstr(str(e))
print(e)
I put some debug prints through the code to check where the program has errors, however the errors appear randomly. Another detail that I noticed is that the ESP 8266, besides connecting to the home network, creates another one called MicroPython-256401 that I also don't know why it appears
wdt reset
tail 0
chksum 0xba
tail 12
chksum 0x2c
ho 0 tail 12 room 4
tail 12
chksum 0x43
csum 0x43
except:
import socket
import dht
import socket as s
import gettime
import esp
esp.osdebug(None)
import gc
gc.collect()
def temperature(d):
d.measure()
time.sleep(1)
return html
def wificonnect():
pass
if 8 <= hour <= 19:
print("dia")
UVB.value(1)
time.sleep(2)
return "on"
print("noite")
UVB.value(0)
time.sleep(2)
return "off"
if 8 <= hour <= 19:
if temp >= 27:
time.sleep(2)
return "off"
time.sleep(2)
return "on"
return "off"
if 8 <= hour <= 19:
if temp <= 18:
time.sleep(2)
return "on"
return "off"
time.sleep(2)
return "off"
if hour == 8:
print("entrou 1")
waterpin.value(1)
time.sleep(15)
waterpin.value(0)
time.sleep(300)
elif hour == 12 :
print("entrou 2")
waterpin.value(1)
time.sleep(15)
waterpin.value(0)
time.sleep(300)
elif hour == 15:
print("entrou 3")
waterpin.value(1)
time.sleep(15)
waterpin.value(0)
time.sleep(300)
elif hour == 18:
print("entrou 4")
waterpin.value(1)
time.sleep(15)
waterpin.value(0)
time.sleep(300)
#defenir lcd
I2C_ADDR = 0x27
totalRows = 2
totalColumns = 16
IP=wificonnect()
s.settimeout(10)
s.listen(1)
waterpin.value(0)
UVB.value(0)
ligthhot.value(0)
UVLIGTH="off"
HOTSPOT="off"
NIGTHHOT="off"
gc.collect()
print("testrede1")
lcd.clear()
lcd.putstr(IP[0])
print("testrede1")
time.sleep(1)
conn.settimeout(3)
conn.close()
print("connecção")
s.settimeout(5)
lcd.clear()
except:
print("hora")
print("UVLIGTH")
lcd.clear()
lcd.putstr(phrase)
print(temp,hum)
print("HOTSPOT")
print("NIGTHHOT")
time.sleep(5)
print("test1")
lcd.clear()
lcd.putstr(IP[0])
time.sleep(2)
print("test2")
lcd.clear()
lcd.putstr(phrase)
lcd.clear()
print("test3")
lcd.putstr(times)
time.sleep(5)
print("test4")
#lcd.putstr(str(e))
print(e)
#lcd.putstr(str(e))
print(e)
