esp8266 compile error
skylin008
Post by skylin008 » Fri Mar 04, 2016 2:10 am
I compiled latest micropython/esp8266 firmware,show follow error message:
fff@cc-b1c25b7d7454 /micropython-master
$ cd esp8266/
fff@cc-b1c25b7d7454 /micropython-master/esp8266
$ ls
Makefile gccollect.h modpybadc.c scripts
README.md gchelper.s modpybpin.c strtoll.c
eagle.rom.addr.v6.ld main.c modpybrtc.c uart.c
esp8266.ld makeimg.py modpybrtc.h uart.h
esp_mphal.c modesp.c moduos.c uart_register.h
esp_mphal.h modnetwork.c modutime.c user_config.h
etshal.h modpyb.c mpconfigport.h utils.c
gccollect.c modpyb.h qstrdefsport.h utils.h
$ make
Use make V=1 or set BUILD_VERBOSE in your environment to increase build verbosit
y.
mkdir -p build/genhdr
GEN build/genhdr/qstrdefs.generated.h
Generating build/genhdr/mpversion.h
mkdir -p build/build
mkdir -p build/lib/libc
mkdir -p build/lib/libm
mkdir -p build/lib/mp-readline
mkdir -p build/lib/netutils
mkdir -p build/lib/timeutils
mkdir -p build/lib/utils
mkdir -p build/py
mkdir -p build/py/../extmod
mkdir -p build/stmhal
CC ../py/mpstate.c
CC ../py/nlrx86.S
CC ../py/nlrx64.S
CC ../py/nlrthumb.S
CC ../py/nlrxtensa.S
CC ../py/nlrsetjmp.c
CC ../py/malloc.c
CC ../py/gc.c
CC ../py/qstr.c
CC ../py/vstr.c
CC ../py/mpprint.c
CC ../py/unicode.c
CC ../py/mpz.c
CC ../py/lexer.c
CC ../py/lexerstr.c
CC ../py/lexerunix.c
CC ../py/parse.c
CC ../py/scope.c
CC ../py/compile.c
CC ../py/emitcommon.c
CC ../py/emitbc.c
CC ../py/asmx64.c
CC ../py/emitnative.c
CC ../py/asmx86.c
CC ../py/asmthumb.c
CC ../py/emitinlinethumb.c
CC ../py/asmarm.c
CC ../py/formatfloat.c
CC ../py/parsenumbase.c
CC ../py/parsenum.c
CC ../py/emitglue.c
CC ../py/runtime.c
CC ../py/nativeglue.c
CC ../py/stackctrl.c
CC ../py/argcheck.c
CC ../py/warning.c
CC ../py/map.c
CC ../py/obj.c
CC ../py/objarray.c
CC ../py/objattrtuple.c
CC ../py/objbool.c
CC ../py/objboundmeth.c
CC ../py/objcell.c
CC ../py/objclosure.c
CC ../py/objcomplex.c
CC ../py/objdict.c
CC ../py/objenumerate.c
CC ../py/objexcept.c
CC ../py/objfilter.c
CC ../py/objfloat.c
CC ../py/objfun.c
CC ../py/objgenerator.c
CC ../py/objgetitemiter.c
CC ../py/objint.c
CC ../py/objint_longlong.c
CC ../py/objint_mpz.c
CC ../py/objlist.c
CC ../py/objmap.c
CC ../py/objmodule.c
CC ../py/objobject.c
CC ../py/objpolyiter.c
CC ../py/objproperty.c
CC ../py/objnone.c
CC ../py/objnamedtuple.c
CC ../py/objrange.c
CC ../py/objreversed.c
CC ../py/objset.c
CC ../py/objsingleton.c
CC ../py/objslice.c
CC ../py/objstr.c
CC ../py/objstrunicode.c
CC ../py/objstringio.c
CC ../py/objtuple.c
CC ../py/objtype.c
CC ../py/objzip.c
CC ../py/opmethods.c
CC ../py/sequence.c
CC ../py/stream.c
CC ../py/binary.c
CC ../py/builtinimport.c
CC ../py/builtinevex.c
CC ../py/modarray.c
CC ../py/modbuiltins.c
CC ../py/modcollections.c
CC ../py/modgc.c
CC ../py/modio.c
CC ../py/modmath.c
CC ../py/modcmath.c
CC ../py/modmicropython.c
CC ../py/modstruct.c
CC ../py/modsys.c
CC ../py/vm.c
CC ../py/bc.c
CC ../py/showbc.c
CC ../py/repl.c
CC ../py/smallint.c
CC ../py/frozenmod.c
CC ../py/../extmod/moductypes.c
CC ../py/../extmod/modujson.c
CC ../py/../extmod/modure.c
CC ../py/../extmod/moduzlib.c
CC ../py/../extmod/moduheapq.c
CC ../py/../extmod/moduhashlib.c
../py/../extmod/moduhashlib.c:37:37: fatal error: lib/axtls/crypto/crypto.h: No
such file or directory
compilation terminated.
make: *** [build/py/../extmod/moduhashlib.o] Error 1
How to solve this issue.TKS!
syrekron
Re: esp8266 compiled error
Post by syrekron » Fri Mar 04, 2016 3:00 am
I just ran into that myself.
If you scroll down in the README.md in the root repo you'll find the answer in the external dependencies section:
Run the following in the root of your copy of the repo:
git submodule update --init
This will fetch additional files and allow the build to complete.
