Call for testsuite running results
pfalcon
Re: [URGENT] Call for testsuite running results
Post by pfalcon » Sat Apr 02, 2016 9:12 pm
Thanks everyone for quick turnaround!
Is this issue (RAM) going to be addressed next?
Sure, how else could it be, especially that it was written in the beginning of this topic ;-) :
The sooner lots of results will be collected, the sooner we'll reach final frontier of the phase 1 of the development: increased heap size.
Awesome MicroPython list
Re: Call for testsuite running results
Post by deshipu » Sun Apr 03, 2016 1:11 pm
With version v1.6-353-g9698a60 on the Adafruit Huzzah Feather, I'm now getting consistently 2 test failures:
FAIL  basics/struct1.py
FAIL  misc/features.py
Not sure if there is any way I could provide more detail?
pfalcon
Post by pfalcon » Sun Apr 03, 2016 1:22 pm
See your own previous message for the information why this happens ;-).
pfalcon
Post by pfalcon » Sun Apr 03, 2016 4:57 pm
Anyway, heap size has been increased in master!
Post by pythoncoder » Thu Apr 07, 2016 9:51 am
[EDITED]I goofed first time. Here are the results [with today's firmware ;)] for an Adafruit Huzzah:
406 tests performed (13217 individual testcases)
406 tests passed
48 tests skipped: builtin_compile class_descriptor exception_chain fun_name ordereddict1 parser slice_attrs string_splitlines machine1 machine_mem urandom_extra vfs_fat_ramdisk bytearray_construct bytes_construct cmath_fun cmath_fun_special complex1 float2int float2int_doubleprec float_divmod int_big_float math_fun_special string_format true_value types meminfo memstats native_closure native_const native_misc viper_addr viper_args viper_binop_arith viper_binop_comp viper_binop_comp_imm viper_binop_multi_comp viper_cond viper_error viper_misc viper_ptr16_load viper_ptr16_store viper_ptr32_load viper_ptr32_store viper_ptr8_load viper_ptr8_store viper_subscr rge_sm sys_exc_info
And on a WeMos D1 mini
406 tests passed
gojimmypi
Post by gojimmypi » Thu Apr 07, 2016 11:59 pm
I'm a little late to party here... for this version from today's git pull:
MicroPython v1.6-380-g9c04299 on 2016-04-07; ESP module with ESP8266
Using one of those China "Geekcreit" NodeMcu Lua boards like this:
http://www.ebay.com/itm/400923947498
I saw these results:
406 tests passed
arek
Post by arek » Wed Apr 13, 2016 4:30 pm
NodeMCU Amica board (from China):
MicroPython v1.7-25-g47442d9 on 2016-04-13; ESP module with ESP8266
406 tests passed
DOIT devkit v2 board (doit.am; also from China):
406 tests passed
While playing "chg_A1:-140" type of messages and AP reconnect messages were getting into test suite way. Disabling/reflashing helped.
gojimmypi
Post by gojimmypi » Wed Apr 13, 2016 10:57 pm
22 tests failed for v1.7-45-g44ab5c3. This was my first build on full Debian in a VM (previously I was using only Raspberry Pi), and tests run from both Debian and Raspberry Pi. Build is from scratch, so everything should be current. Flash appeared to be successful, no errors reported.
Startup:
�ò�ì�pìl�xcl`��do�xsläd�÷ioctl(1, 0)
ioctl(5, 0)
readblocks(0, 3ffeeda0(4096))
readblocks(2, 3ffeedf0(4096))
could not open file 'boot.py' for reading
could not open file 'main.py' for reading
#4 ets_task(4010029c, 3, 3fff4668, 4)
MicroPython v1.7-45-g44ab5c3 on 2016-04-13; ESP module with ESP8266
I fetched all the latest code like this (see post for my full build process: http://forum.micropython.org/viewtopic.php?f=16&t=1720):
git submodule update --init
git fetch origin
git pull
# the next git commmands are suggested on https://github.com/pfalcon/esp-open-sdk
git submodule sync
Both the old test script, then fresh git fetch test script resulted in errors.
Here is the full output:
pi@rp-machine ~/workspace/micropython/tests $ ./run-tests --target esp8266 --device /dev/ttyUSB0
pass  basics/0prelim.py
pass  basics/andor.py
pass  basics/array1.py
pass  basics/array_add.py
pass  basics/array_construct.py
pass  basics/array_construct2.py
pass  basics/array_construct_endian.py
  File "basics/array_q.py", line 5, in <module>
    print(array('q'))
ValueError: bad typecode (must be b, B, u, h, H, i, I, l, L, f or d)
FAIL  basics/array_q.py
pass  basics/assign1.py
pass  basics/async_await.py
pass  basics/async_await2.py
pass  basics/async_for.py
pass  basics/async_for2.py
pass  basics/async_with.py
pass  basics/async_with2.py
  File "basics/attrtuple1.py", line 5, in <module>
    t = sys.implementation
AttributeError: 'module' object has no attribute 'implementation'
FAIL  basics/attrtuple1.py
pass  basics/bool1.py
pass  basics/boundmeth1.py
pass  basics/break.py
pass  basics/builtin_abs.py
pass  basics/builtin_allany.py
pass  basics/builtin_bin.py
pass  basics/builtin_callable.py
pass  basics/builtin_chr.py
skip  basics/builtin_compile.py
pass  basics/builtin_dir.py
pass  basics/builtin_divmod.py
pass  basics/builtin_ellipsis.py
pass  basics/builtin_eval.py
pass  basics/builtin_eval_error.py
pass  basics/builtin_hash.py
pass  basics/builtin_hex.py
pass  basics/builtin_id.py
pass  basics/builtin_issubclass.py
pass  basics/builtin_len1.py
  File "basics/builtin_minmax.py", line 34, in <module>
    print(min([1, 2, 3, 4, 5], default=-1))
TypeError: min() got an unexpected keyword argument
FAIL  basics/builtin_minmax.py
pass  basics/builtin_oct.py
pass  basics/builtin_ord.py
pass  basics/builtin_override.py
pass  basics/builtin_pow.py
pass  basics/builtin_property.py
  File "basics/builtin_range.py", line 38, in <module>
    print(range(1, 2, 3).start)
AttributeError: 'range' object has no attribute 'start'
FAIL  basics/builtin_range.py
pass  basics/builtin_reversed.py
pass  basics/builtin_round.py
pass  basics/builtin_slice.py
pass  basics/builtin_sorted.py
pass  basics/builtin_sum.py
pass  basics/builtin_type.py
pass  basics/bytearray1.py
pass  basics/bytearray_add.py
pass  basics/bytearray_append.py
pass  basics/bytearray_construct.py
pass  basics/bytearray_construct_endian.py
pass  basics/bytearray_longint.py
pass  basics/bytearray_slice_assign.py
  File "basics/bytes.py", line 4
    print(rb'123')
SyntaxError: invalid syntax
FAIL  basics/bytes.py
pass  basics/bytes_add.py
pass  basics/bytes_add_endian.py
pass  basics/bytes_compare.py
pass  basics/bytes_compare2.py
pass  basics/bytes_construct.py
pass  basics/bytes_construct_endian.py
pass  basics/bytes_count.py
pass  basics/bytes_find.py
pass  basics/bytes_format_modulo.py
pass  basics/bytes_gen.py
pass  basics/bytes_large.py
pass  basics/bytes_mult.py
pass  basics/bytes_partition.py
pass  basics/bytes_replace.py
pass  basics/bytes_split.py
pass  basics/bytes_strip.py
pass  basics/bytes_subscr.py
pass  basics/class1.py
pass  basics/class2.py
pass  basics/class3.py
pass  basics/class_bind_self.py
pass  basics/class_binop.py
pass  basics/class_call.py
pass  basics/class_contains.py
skip  basics/class_descriptor.py
pass  basics/class_emptybases.py
pass  basics/class_getattr.py
pass  basics/class_inherit1.py
pass  basics/class_inherit_mul.py
pass  basics/class_instance_override.py
pass  basics/class_item.py
pass  basics/class_new.py
pass  basics/class_number.py
pass  basics/class_staticclassmethod.py
pass  basics/class_store.py
pass  basics/class_store_class.py
pass  basics/class_str.py
pass  basics/class_super.py
pass  basics/class_super_object.py
pass  basics/class_use_other.py
pass  basics/closure1.py
pass  basics/closure2.py
pass  basics/closure_defargs.py
pass  basics/closure_manyvars.py
pass  basics/closure_namedarg.py
pass  basics/compare_multi.py
pass  basics/comprehension1.py
pass  basics/containment.py
pass  basics/continue.py
pass  basics/decorator.py
pass  basics/del_attr.py
pass  basics/del_deref.py
pass  basics/del_global.py
pass  basics/del_local.py
pass  basics/del_name.py
pass  basics/del_subscr.py
pass  basics/dict1.py
pass  basics/dict2.py
pass  basics/dict_clear.py
pass  basics/dict_construct.py
pass  basics/dict_copy.py
^[[B^[[B^[[Bpass  basics/dict_del.py
pass  basics/dict_from_iter.py
pass  basics/dict_fromkeys.py
pass  basics/dict_get.py
pass  basics/dict_intern.py
pass  basics/dict_iterator.py
pass  basics/dict_pop.py
pass  basics/dict_popitem.py
pass  basics/dict_setdefault.py
pass  basics/dict_specialmeth.py
pass  basics/dict_update.py
pass  basics/dict_views.py
pass  basics/enumerate.py
pass  basics/equal.py
pass  basics/equal_class.py
pass  basics/except_match_tuple.py
  File "basics/exception1.py", line 13, in <module>
    print(s.value)
AttributeError: 'StopIteration' object has no attribute 'value'
FAIL  basics/exception1.py
skip  basics/exception_chain.py
pass  basics/exceptpoly.py
pass  basics/exceptpoly2.py
pass  basics/exec1.py
pass  basics/filter.py
pass  basics/floordivide.py
pass  basics/for1.py
pass  basics/for2.py
pass  basics/for3.py
pass  basics/for_break.py
pass  basics/for_range.py
pass  basics/for_return.py
pass  basics/frozenset1.py
pass  basics/frozenset_add.py
pass  basics/frozenset_binop.py
pass  basics/frozenset_copy.py
pass  basics/frozenset_difference.py
pass  basics/frozenset_set.py
pass  basics/fun1.py
pass  basics/fun2.py
pass  basics/fun3.py
pass  basics/fun_annotations.py
pass  basics/fun_calldblstar.py
pass  basics/fun_callstar.py
pass  basics/fun_callstardblstar.py
pass  basics/fun_defargs.py
pass  basics/fun_defargs2.py
pass  basics/fun_error.py
pass  basics/fun_kwargs.py
pass  basics/fun_kwonly.py
pass  basics/fun_kwonlydef.py
pass  basics/fun_kwvarargs.py
pass  basics/fun_largestate.py
skip  basics/fun_name.py
pass  basics/fun_str.py
pass  basics/fun_varargs.py
pass  basics/gc1.py
  File "basics/gen_yield_from.py", line 9
    print((yield from gen()))
FAIL  basics/gen_yield_from.py
  File "basics/gen_yield_from_close.py", line 9
FAIL  basics/gen_yield_from_close.py
  File "basics/gen_yield_from_ducktype.py", line 16
    yield from MyGen()
FAIL  basics/gen_yield_from_ducktype.py
  File "basics/gen_yield_from_exc.py", line 8
FAIL  basics/gen_yield_from_exc.py
  File "basics/gen_yield_from_iter.py", line 2
    yield from (1, 2, 3)
FAIL  basics/gen_yield_from_iter.py
  File "basics/gen_yield_from_send.py", line 6
FAIL  basics/gen_yield_from_send.py
  File "basics/gen_yield_from_throw.py", line 10
FAIL  basics/gen_yield_from_throw.py
  File "basics/generator1.py", line 12
    return None
SyntaxError: 'return' with argument inside generator
FAIL  basics/generator1.py
pass  basics/generator2.py
pass  basics/generator_args.py
pass  basics/generator_close.py
pass  basics/generator_closure.py
pass  basics/generator_exc.py
  File "basics/generator_return.py", line 3
    return 42
FAIL  basics/generator_return.py
pass  basics/generator_send.py
pass  basics/getattr.py
pass  basics/getattr1.py
pass  basics/getitem.py
pass  basics/globals_del.py
pass  basics/hasattr1.py
pass  basics/ifcond.py
pass  basics/int1.py
pass  basics/int2.py
pass  basics/int_big_and.py
pass  basics/int_big_and2.py
pass  basics/int_big_and3.py
pass  basics/int_big_cmp.py
pass  basics/int_big_div.py
pass  basics/int_big_error.py
pass  basics/int_big_lshift.py
pass  basics/int_big_mod.py
pass  basics/int_big_mul.py
pass  basics/int_big_or.py
pass  basics/int_big_or2.py
pass  basics/int_big_or3.py
pass  basics/int_big_pow.py
pass  basics/int_big_rshift.py
pass  basics/int_big_unary.py
pass  basics/int_big_xor.py
pass  basics/int_big_xor2.py
pass  basics/int_big_xor3.py
pass  basics/int_big_zeroone.py
pass  basics/int_bytes.py
pass  basics/int_constfolding.py
pass  basics/int_divmod.py
pass  basics/int_divzero.py
pass  basics/int_long.py
pass  basics/int_mpz.py
pass  basics/int_small.py
pass  basics/is_isnot.py
pass  basics/iter0.py
pass  basics/iter1.py
pass  basics/iter2.py
pass  basics/iter_of_iter.py
pass  basics/lambda1.py
pass  basics/lambda_defargs.py
  File "basics/lexer.py", line 48, in <module>
    exec(r"b'\x0'")
ValueError: invalid \x escape
FAIL  basics/lexer.py
pass  basics/list1.py
  File "basics/list_clear.py", line 3, in <module>
    x.clear()
AttributeError: 'list' object has no attribute 'clear'
FAIL  basics/list_clear.py
pass  basics/list_compare.py
  File "basics/list_copy.py", line 3, in <module>
    b = a.copy()
AttributeError: 'list' object has no attribute 'copy'
FAIL  basics/list_copy.py
pass  basics/list_count.py
pass  basics/list_extend.py
pass  basics/list_index.py
pass  basics/list_insert.py
pass  basics/list_mult.py
pass  basics/list_pop.py
pass  basics/list_remove.py
pass  basics/list_reverse.py
pass  basics/list_slice.py
pass  basics/list_slice_3arg.py
pass  basics/list_slice_assign.py
pass  basics/list_slice_assign_grow.py
pass  basics/list_sort.py
pass  basics/list_sum.py
pass  basics/map.py
pass  basics/memoryerror.py
  File "basics/memoryview1.py", line 19, in <module>
    m[0] = 1
TypeError: 'int' does not support the buffer interface
FAIL  basics/memoryview1.py
  File "basics/memoryview_gc.py", line 6, in <module>
    m[i] = i
FAIL  basics/memoryview_gc.py
pass  basics/module1.py
pass  basics/module2.py
pass  basics/namedtuple1.py
pass  basics/object1.py
pass  basics/object_dict.py
pass  basics/object_new.py
pass  basics/op_error.py
skip  basics/ordereddict1.py
skip  basics/parser.py
pass  basics/print.py
pass  basics/python34.py
pass  basics/return1.py
pass  basics/scope.py
pass  basics/self_type_check.py
pass  basics/seq_unpack.py
pass  basics/set1.py
pass  basics/set_add.py
pass  basics/set_binop.py
pass  basics/set_clear.py
pass  basics/set_copy.py
pass  basics/set_difference.py
pass  basics/set_discard.py
pass  basics/set_intersection.py
pass  basics/set_isdisjoint.py
pass  basics/set_isfooset.py
pass  basics/set_iter.py
pass  basics/set_pop.py
pass  basics/set_remove.py
pass  basics/set_specialmeth.py
pass  basics/set_symmetric_difference.py
pass  basics/set_union.py
pass  basics/set_unop.py
pass  basics/set_update.py
pass  basics/setattr1.py
skip  basics/slice_attrs.py
pass  basics/slots_bool_len.py
  File "basics/string1.py", line 6
    print(u'abc')
FAIL  basics/string1.py
pass  basics/string_compare.py
pass  basics/string_count.py
pass  basics/string_cr_conversion.py
pass  basics/string_crlf_conversion.py
pass  basics/string_endswith.py
pass  basics/string_escape.py
pass  basics/string_find.py
pass  basics/string_format.py
pass  basics/string_format2.py
pass  basics/string_format_error.py
pass  basics/string_format_modulo.py
pass  basics/string_index.py
pass  basics/string_istest.py
pass  basics/string_join.py
pass  basics/string_large.py
pass  basics/string_mult.py
pass  basics/string_partition.py
pass  basics/string_replace.py
pass  basics/string_repr.py
pass  basics/string_rfind.py
pass  basics/string_rindex.py
pass  basics/string_rpartition.py
pass  basics/string_rsplit.py
pass  basics/string_slice.py
pass  basics/string_split.py
  File "basics/string_splitlines.py", line 12, in <module>
    print("foo\nbar".splitlines(keepends=True))
TypeError: splitlines() takes no keyword arguments
skip  basics/string_splitlines.py
pass  basics/string_startswith.py
pass  basics/string_strip.py
pass  basics/string_upperlow.py
pass  basics/struct1.py
pass  basics/subclass_classmethod.py
pass  basics/subclass_native1.py
pass  basics/subclass_native2_list.py
pass  basics/subclass_native2_tuple.py
pass  basics/subclass_native3.py
pass  basics/subclass_native4.py
pass  basics/subclass_native5.py
pass  basics/subclass_native_buffer.py
pass  basics/subclass_native_cmp.py
pass  basics/subclass_native_specmeth.py
pass  basics/syntaxerror.py
  File "basics/sys1.py", line 10, in <module>
    print(sys.implementation.name in ('cpython', 'micropython'))
FAIL  basics/sys1.py
pass  basics/true_value.py
pass  basics/try1.py
pass  basics/try2.py
pass  basics/try3.py
pass  basics/try4.py
pass  basics/try_as_var.py
pass  basics/try_continue.py
pass  basics/try_error.py
pass  basics/try_finally1.py
pass  basics/try_finally_loops.py
pass  basics/try_finally_return.py
pass  basics/try_finally_return2.py
pass  basics/try_reraise.py
pass  basics/try_reraise2.py
pass  basics/tuple1.py
pass  basics/tuple_compare.py
pass  basics/tuple_count.py
pass  basics/tuple_index.py
pass  basics/tuple_mult.py
pass  basics/types1.py
pass  basics/types2.py
pass  basics/unary_op.py
pass  basics/unboundlocal.py
pass  basics/unpack1.py
pass  basics/while1.py
pass  basics/while_cond.py
pass  basics/while_nest_exc.py
pass  basics/with1.py
pass  basics/with_break.py
pass  basics/with_continue.py
pass  basics/with_return.py
pass  basics/zip.py
skip  extmod/machine1.py
skip  extmod/machine_mem.py
pass  extmod/sha256.py
pass  extmod/time_ms_us.py
pass  extmod/ubinascii_a2b_base64.py
pass  extmod/ubinascii_b2a_base64.py
pass  extmod/ubinascii_hexlify.py
pass  extmod/ubinascii_unhexlify.py
pass  extmod/uctypes_array_assign_le.py
pass  extmod/uctypes_array_assign_native_le.py
pass  extmod/uctypes_bytearray.py
pass  extmod/uctypes_le.py
pass  extmod/uctypes_le_float.py
pass  extmod/uctypes_native_float.py
pass  extmod/uctypes_native_le.py
pass  extmod/uctypes_ptr_le.py
pass  extmod/uctypes_ptr_native_le.py
pass  extmod/uctypes_sizeof.py
pass  extmod/uctypes_sizeof_native.py
pass  extmod/uheapq1.py
pass  extmod/ujson_dumps.py
pass  extmod/ujson_dumps_extra.py
pass  extmod/ujson_dumps_float.py
pass  extmod/ujson_loads.py
pass  extmod/ujson_loads_float.py
pass  extmod/urandom_basic.py
skip  extmod/urandom_extra.py
pass  extmod/ure1.py
pass  extmod/ure_error.py
pass  extmod/ure_group.py
pass  extmod/ure_namedclass.py
pass  extmod/ure_split.py
skip  extmod/vfs_fat_ramdisk.py
pass  extmod/zlibd_decompress.py
pass  float/array_construct.py
pass  float/builtin_float_minmax.py
pass  float/builtin_float_round.py
skip  float/bytearray_construct.py
skip  float/bytes_construct.py
skip  float/cmath_fun.py
skip  float/cmath_fun_special.py
skip  float/complex1.py
pass  float/float1.py
skip  float/float2int.py
skip  float/float2int_doubleprec.py
pass  float/float2int_fp30.py
pass  float/float_array.py
skip  float/float_divmod.py
pass  float/float_divmod_relaxed.py
pass  float/float_struct.py
skip  float/int_big_float.py
pass  float/int_divzero.py
pass  float/int_power.py
pass  float/list_index.py
pass  float/math_fun.py
pass  float/math_fun_bool.py
  File "float/math_fun_special.py", line 16, in <module>
    ('log2', log2, test_values),
NameError: name 'log2' is not defined
skip  float/math_fun_special.py
skip  float/string_format.py
pass  float/string_format2.py
pass  float/string_format_fp30.py
pass  float/string_format_modulo.py
pass  float/string_format_modulo2.py
skip  float/true_value.py
skip  float/types.py
pass  micropython/const.py
pass  micropython/const_error.py
pass  micropython/decorator.py
pass  micropython/decorator_error.py
pass  micropython/heapalloc.py
skip  micropython/meminfo.py
skip  micropython/memstats.py
skip  micropython/native_closure.py
skip  micropython/native_const.py
skip  micropython/native_misc.py
skip  micropython/viper_addr.py
skip  micropython/viper_args.py
skip  micropython/viper_binop_arith.py
skip  micropython/viper_binop_comp.py
skip  micropython/viper_binop_comp_imm.py
skip  micropython/viper_binop_multi_comp.py
skip  micropython/viper_cond.py
skip  micropython/viper_error.py
skip  micropython/viper_misc.py
skip  micropython/viper_ptr16_load.py
skip  micropython/viper_ptr16_store.py
skip  micropython/viper_ptr32_load.py
skip  micropython/viper_ptr32_store.py
skip  micropython/viper_ptr8_load.py
skip  micropython/viper_ptr8_store.py
skip  micropython/viper_subscr.py
pass  misc/features.py
pass  misc/non_compliant.py
pass  misc/non_compliant_lexer.py
pass  misc/print_exception.py
pass  misc/recursion.py
pass  misc/recursive_data.py
pass  misc/recursive_iternext.py
skip  misc/rge_sm.py
skip  misc/sys_exc_info.py
412 tests performed (13111 individual testcases)
390 tests passed
22 tests failed: array_q attrtuple1 builtin_minmax builtin_range bytes exception1 gen_yield_from gen_yield_from_close gen_yield_from_ducktype gen_yield_from_exc gen_yield_from_iter gen_yield_from_send gen_yield_from_throw generator1 generator_return lexer list_clear list_copy memoryview1 memoryview_gc string1 sys1
edit: I am using a "Geekcreit" board like this one: http://www.banggood.com/Geekcreit-Doit- ... 85891.html
gojimmypi
Post by gojimmypi » Thu Apr 14, 2016 9:01 pm
today the ./run-tests is not working for me (fetching everything fresh from today on github: esp-open-sdk, esptool, micropython ).
Error is: ImportError: No module named 'serial'
mylogin@mymachine:~$ ~/workspace/micropython/tests/run-tests --target esp8266 --device /dev/ttyUSB0
  File "/home/mylogin/workspace/micropython/tests/run-tests", line 388, in <module>
    main()
  File "/home/mylogin/workspace/micropython/tests/run-tests", line 356, in main
    pyb = pyboard.Pyboard(args.device, args.baudrate, args.user, args.password)
  File "/home/mylogin/workspace/micropython/tests/pyboard.py", line 125, in __init__
    import serial
I am able to get the device ID:
mylogin@mymachine:~$ ~/workspace/esptool/esptool.py --port /dev/ttyUSB0 flash_id
Connecting...
Manufacturer: e0
Device: 4016
this is all with the latest code from today (v1.7-55-g272fad6 - April 14). I am able to flash, and connect to the device:
¦¦o¦¦¦¦cxc¦¦¦¦¦¦¦¦p¦l¦pcl`¦¦lo¦psl¦d¦¦ioctl(1, 0)
ioctl(5, 0)
readblocks(0, 3ffeed90(4096))
readblocks(2, 3ffeede0(4096))
#4 ets_task(401002a4, 3, 3fff4658, 4)
MicroPython v1.7-55-g272fad6 on 2016-04-14; ESP module with ESP8266
tried resetting ESP8266, recompiling, etc.
Post by pythoncoder » Fri Apr 15, 2016 6:28 am
I think you need to install pyserial
sudo pip install pyserial
