Page 1 of 4
Call for testsuite running results
Posted: Fri Apr 01, 2016 10:54 pm
by pfalcon
We've approached an important milestone in ESP8266 port development: a moment when MicroPython testsuite passes successfully. Well, it passes for me, and I would like to collect as wide results as possible. The sooner lots of results will be collected, the sooner we'll reach final frontier of the phase 1 of the development: increased heap size.
Instructions:
1. Make sure you followed background requirements in
http://forum.micropython.org/viewtopic.php?f=16&t=1689
2. esptool.py erase_flash
3. make deploy
4.
cd ../tests
./run-tests --target esp8266 --device /dev/ttyUSB0
Re: [URGENT] Call for testsuite running results
Posted: Sat Apr 02, 2016 3:20 am
by slzatz
Adafruit Feather Huzzah esp8266. Looks good.
405 tests performed (13213 individual testcases)
405 tests passed
48 tests skipped: builtin_compile class_descriptor exception_chain fun_name ordereddict1 parser slice_attrs string_splitlines machine1 machine_mem urandom_extra vfs_fat_ramdisk bytearray_construct bytes_construct cmath_fun cmath_fun_special complex1 float2int float2int_doubleprec float_divmod int_big_float math_fun_special string_format true_value types meminfo memstats native_closure native_const native_misc viper_addr viper_args viper_binop_arith viper_binop_comp viper_binop_comp_imm viper_binop_multi_comp viper_cond viper_error viper_misc viper_ptr16_load viper_ptr16_store viper_ptr32_load viper_ptr32_store viper_ptr8_load viper_ptr8_store viper_subscr rge_sm sys_exc_info
slzatz@slzatz-ThinkPad-X200:~/micropython/tests$
Posted: Sat Apr 02, 2016 5:59 am
by numero_trey
Ran it on a $9 NodeMCU knockoff and it passes for me. Have run the suite about a dozen times.
Posted: Sat Apr 02, 2016 7:03 am
by vfl68
On the Olimex MOD-WIFI-ESP8266-DEV it seems ok too :
405 tests passed
Posted: Sat Apr 02, 2016 8:10 am
by pfalcon
Thanks for quick response guys! Looking for more reports...
Posted: Sat Apr 02, 2016 8:30 am
by mianos
NodeMCU from aliexpress:
405 tests passed
WEMOS D1:
405 tests passed
Itead studio 'sonoff' ESP with a PSU and relay on board.
405 tests passed
An original ESP01 (Flash id 1340C8, I think this one was a 1MBit flash or maybe even a 512K, it's old)
405 tests passed
(It might be useful to capture the flash id with esp.flash_id() too. Being such an integrated part, that's the only real difference).
Posted: Sat Apr 02, 2016 12:51 pm
by gschmott
Passed on a generic ESP-12 module soldered onto a board:
405 tests passed
Of course trying to connect to my access point fails unless I drop my heap-size down to 11KB. Is this issue (RAM) going to be addressed next? Kind limited having an ESP8266 that can't connect to the Internet
Posted: Sat Apr 02, 2016 7:08 pm
by wendlers
Tests pass on
Geekcreit NodeMcu (ESP-12E, e. g.
http://www.banggood.com/Geekcreit-Doit- ... 85891.html)
405 tests passed
Posted: Sat Apr 02, 2016 7:13 pm
by wendlers
Tests pass on
LoLin V3 NodeMcu (ESP-12E, e. g.
http://www.banggood.com/V3-NodeMcu-Lua- ... 92733.html)
405 tests passed
Posted: Sat Apr 02, 2016 7:57 pm
by deshipu
I ran the tests on Adafruit Huzzah Feather. Initially, I forgot to apply the patch, and had two tests fail:
FAIL basics/struct1.py
FAIL misc/features.py
But they didn't output any debugging information or anything. Then I tried again with the patch, and all tests passed.
Then I tried with an ESP-01 module, and got one failure:
I reset the module and tried again, and this time all tests passed. I blame serial communication errors.
