Cannot (re) flash new firmware-combined.bin
Hi;
Sorry for my english. I'm new with micropython, and I have a ESP 8266-01 module (1M memory)
I managed to flash my first compiled fimrmware-combined-bin (with vagrant / virtualbox).
First test, with FTDI and external alim 3.3v : good but error with tests import pyb and test.
Ok. Y compile new version of firmware-combined.bin, but !!!!
Unable to acces my esp with same command and same connection:
[code]
python ./esptool/esptool.py -p /dev/ttyUSB0 write_flash 0x00 ./esp8266-micropython-vagrant/firmware-combined.bin -fm dio -fs 32m -ff 40m
[/code]
My tests with screen at boot with speed: 74880 baud
[code]
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x40100000, len 31964, room 16
tail 12
chksum 0x52
ho 0 tail 12 room 4
load 0x3ffe8000, len 996, room 12
tail 8
chksum 0x49
load 0x3ffe83f0, len 29852, room 0
tail 12
chksum 0x1f
csum 0x1f
#0 ets_task(40210970, 31, 3ffef8a0, 4)
�q���*�nE����n=�#1 ets_task(40220250, 32, 3fff0860, 34)
#2 ets_task(4021f324, 20, 3fff05f0, 3)
SDK ver: 1.5.2(80914727) compiled @ Jan 29 2016 17:26:12
phy ver: 484, pp ver: 9.6
[/code]
My tests with screen at boot with speed: 115200 baud
[code]
rl��r��#�n������p�<����x��ǒ��p�nn��;�nĒ���b�#l`nn��܀���l���b�n��n�䎂l��8��nn����l`��#�n�$�l`�`rn|��n�����l`�~����#�n�$����nn���l`nn��܀�r����pp��<��l�b�ľ~�n���l`��#�n�rnr���;��?�lrp�n��܀�r�����8p��<��l�l��b�ľ~�n���r��#�n�$��l`�8`rn|��n�����`渎��;��?���;|������|nb���l�l�p�lp�����l8�b��#l`�don't use rtc mem data
ll��r�� �r�'b�������p��p�������p��cl`䈌�����|nb��lr���8�p������l��8�lr�ùl�Ğ����br�b� ��l����#�n�߱�n��܀ �c�n�Ď�����l������l�l`�`�ܒ��b��b����ܒ��b�b�$`nĒ���<�� l�could not find module 'boot'
MicroPython v1.6-329-g4b597a1 on 2016-04-01; ESP module with ESP8266
>>> #5 ets_task(40100440, 3, 3fff9598, 4)
ets_alt_task: ets_run
q for task 2: queue: 3fff96b8, get ptr: 0, put ptr: 0, qlen: 16
q for task 3: queue: 3fff9598, get ptr: 0, put ptr: 0, qlen: 4
q for task 20: queue: 3fff05f0, get ptr: 0, put ptr: 0, qlen: 3
q for task 28: queue: 3fffa328, get ptr: 0, put ptr: 0, qlen: 10
q for task 31: queue: 3ffef8a0, get ptr: 0, put ptr: 0, qlen: 4
q for task 32: queue: 3fff0860, get ptr: 0, put ptr: 2, qlen: 34
scandone
no [my network] found, reconnect after 1s
reconnect
f 0, scandone
reconnect
f -180, scandone
reconnect
f r0, scandone
reconnect
[/code]
If I 'm not home, the module searches the network and I have no hand (in [my neywork] = the name of my network, modified here)
But, in my home, no problem.
So, no boot module, and no acces to flash.
I'm hopeless. My esp-01 is not bricked, but I can not re flasher.
Can you help me please?
R. Suinot.
[code]
[/code]
[code]
tail 12
chksum 0x52
ho 0 tail 12 room 4
tail 8
chksum 0x49
tail 12
chksum 0x1f
csum 0x1f
[/code]
[code]
scandone
reconnect
f 0, scandone
reconnect
f -180, scandone
reconnect
f r0, scandone
reconnect
[/code]
R. Suinot.
Re: dont (re) flash new firmware-combined.bin
Did you forget to pull the GPIO0 down to bring your module into flashing mode?
No, I tested with
GPIO0 -> GND
and
GPIO0 -> GND
GPIO2 -> R10K -> 3.3v
Same result (for flashing)
No, I tested with
GPIO0 -> GND
and
GPIO0 -> GND
Do you also have GPIO15 pulled down?
In ESP8266-01, I have just GPIO0 and GPIO2 and, of cource, rt/tx/gnd/3.3v, CH_PD, RST.deshipu wrote:Do you also have GPIO15 pulled down?
My first flash of micropython work (not good, but work) but, impossible of flashing a second time.
I'm desperate
Yeee!!!!
After multiple attempts and connections, that's work!!!
For which the same problems, the connections is (in esp-01):
power supply for VCC and CH_PD is external power ( 5v->3.3v)
Thank you for taking the time to help me .
Rémi.
remi@unimatrice:/home/remi/sketchbook/Compilations$ ./esptool/esptool.py --port /dev/ttyUSB0 --baud 115200 write_flash 0x00 ./esp8266-micropython-vagrant/firmware-combined.bin -fm dio -fs 32m -ff 40m
Connecting...
Erasing flash...
Took 2.13s to erase flash block
Wrote 409600 bytes at 0x00000000 in 39.6 seconds (82.7 kbit/s)...
Leaving...
Rx <--------> tx | GND <-------> GND power and FTDI
3.3v <-> R=10k <-> CH_PD | GPIO2
RST | GPIO0 <--------> R=10k <-> GND
3.3v <-------> VCC | rx <--------------> TX
Rémi.
I'm glad you resolved it. I think it's generally impossible to break the ESP8266 by bad flashing -- unless you break the flash memory itself somehow. The boot mode selection comes before the module even looks at the flashed code, so no way you could break that. Power is, however, a common source of problems with this module, as it takes a bit more than the USB2TTL can give it.
Yes, the power supply is a problem. I think my problem was on two level:deshipu wrote:I'm glad you resolved it. I think it's generally impossible to break the ESP8266 by bad flashing -- unless you break the flash memory itself somehow. The boot mode selection comes before the module even looks at the flashed code, so no way you could break that. Power is, however, a common source of problems with this module, as it takes a bit more than the USB2TTL can give it.
1/ no Resistor in GPIO0 nor CH_PD
2/ I flashing 1 second after connecting power.
Now , I have the soft problems. But this is something else.
Thank's.
Re: Cannot (re) flash new firmware-combined.bin
Note that official README contains troubleshooting section to give ESP8266 newbies some pointers: https://github.com/micropython/micropyt ... leshooting .
Awesome MicroPython list
