Determine flash size on your module
c.man
Re: Determine flash size on your module
Post by c.man » Fri Jul 28, 2017 10:24 am
ok. But Is it possible to use the free space to save information ? (ex. temperature acquisition, time, etc)
Post by pythoncoder » Sat Jul 29, 2017 10:09 am
You can save data to the filesystem using Python file I/O.
c.man
Post by c.man » Sun Sep 03, 2017 1:22 pm
pfalcon wrote:MicroPython ESP8266 port (in git master) now includes "port_diag" module to query various diagnostic information about port/board for own review or submitting with bug reports. Use it as:
import port_diag
It will be extended over time.
I tried with port_diag library in ESP32 with last micropython, but don't work. Why ?
Post by Roberthh » Sun Sep 03, 2017 8:00 pm
For both the ESP8266 and ESP32 port, you can use
import esp
esp.flash_size()
to get the flash_size, which is seen and used by MicroPython. That may be less then the physical flash size, and is shared by both the firmware and the file system.
Ricardo
Post by Ricardo » Sun Dec 15, 2019 2:22 am
Hello, MicroPython World! :D
Sorry to bump such an old thread, but I'd like to share some information that could be helpful to others.
As a complete newbie, I wanted to find out how much flash my modules have to know if I could use MicroPython on them - but I received no manual, specs or any kind of details about the modules, and my research on the web produced conflicting results.
So at first I just used the AT commands to get information directly from the module using a terminal software (Putty on Windows). I connected a USB to TTL cable (3.3V) to the module like this:
VCC <-> VCC, GND <-> GND, TX <-> RX, RX <-> TX, VCC <-> CH_PD
Then I connected the cable to PC, opened the terminal software and connected to the board. I pressed:
AT+RST[ENTER][CTRL+J]
and got:
ets Jan 8 2013,rst cause:4, boot mode:(3,7)
wdt reset
load 0x40100000, len 1396, room 16
tail 4
chksum 0x89
load 0x3ffe8000, len 776, room 4
tail 4
chksum 0xe8
load 0x3ffe8308, len 540, room 4
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
SPI Speed : 40MHz
SPI Mode : DIO
SPI Flash Size & Map: 8Mbit(512KB+512KB)
jump to run user1 @ 1000
rl▒▒rl▒▒
Ai-Thinker Technology Co.,Ltd.
ready
So it seems my board does have 1 MB of flash! :D
I still wanted to test the OP method, but I noticed right away that the link to https://code.coreboot.org/svn/flashrom/ ... ashchips.h is currently dead. Yet, I set the board into bootloader mode (adding these connections to the board):
GND <-> GPIO0, VCC <-> GPIO2
... and run:
esptool.py --port COM5 flash_id
... the output directly showed the amount of flash (with no need to consult any other sources):
Detecting chip type... ESP8266
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: ..:..:..:..:..:..
Uploading stub...
Running stub...
Stub running...
Manufacturer: e0
Device: 4014
Detected flash size: 1MB
Hard resetting via RTS pin...
I hope this helps other newbies like me. ;)
