Using the tx/rx pins not for UART
mmh
Re: Using the tx/rx pins not for UART
Postby mmh » Thu Mar 09, 2017 5:36 pm
Circling back on this feature which I still think is needed for ESP8266.
This feature end up being a lot more than I had expected, the original patch provided earlier I had added and tried to work into the code base was reject because it was a bit of a one off and the group wants to keep things clean which makes perfect sense to me. Here is the original pull request https://github.com/micropython/micropython/pull/2814.
After working with the team they suggested having the ability to apply dupterm to the UART and having a TERM slot in the global database. I added a series of commits that work in the suggested direction they can be seen here:
https://github.com/micropython/micropython/pull/2891
I know the team is busy with other things at the moment and this PR is very complex, it appears to work for me and I have been using it but it would be great to get some other folks who have interest contributing here just by using it and creating a dialog on that PR to help sort out if we want it or not.
mohpor82
Postby mohpor82 » Wed Apr 19, 2017 10:02 am
Hi Marc,
As I have commented on your second PR, there seems to be a problem with the UART rx buffers, it keeps only 15 bytes and readline() or read() keeps waiting for input.
Are you still interested in this project?
Return to “ESP8266 boards”
Who is online
Users browsing this forum: Google [Bot] and 1 guest
