LED shines when GPIO2 low on ESP-12?
I just noticed a strange thing. If I set the GPIO2 pin to low (or enable PWM on it), the blue serial LED, which normally blinks when there is serial communication, switches on. I would expect that LED to be connected to GPIO3 or GPIO1, not GPIO2, so I'm not sure what is happening there. Anybody had a similar experience?
Re: LED shines when GPIO2 low on ESP-12?
Nope, seems okay here. I have ESP12-E. Tried both PWM and Pin.OUT/Pin.IN set to low for pin 2. Does the LED turn off when you set the pin to other values (high or PWM)?
Yes, ESP-12 has an on-module blue LED, on GPIO2, active low. I don't see it blinking with serial communication (except for when using BootROM bootloader for programming, but that's bootloader blinking it, not serial communication, i.e. it in no way tied to UART).
Awesome MicroPython list
That makes sense, thanks.
At the bootloader time, everything from GPIO1 is echoed on GPIO2 (possibly for debugging), so that would explain why it blinks then.
A bit better explanation is that GPIO2 is TXD1, i.e. TX of TX-only UART1, intended to be used for logging. Apparently, bootloader dumps quite a lot there. It would be interesting to see what it writes there, I don't believe I ever saw someone describing that (I bet it's 74880 baud or whatever it is).
This made me think: we forgot to disable OS logging to UART0 in the release %).
