ESP8266 doesn't connect to WiFi using WPA2/TKIP
zeevro
Post by zeevro » Tue May 10, 2016 1:27 am
This is the module I'm using: http://www.electrodragon.com/product/wi ... d-esp8266/
WiFi Router is MikroTik 951-2n
It connects OK to my android phone's AP, and also to the neighbor's free network. Get's an IP address and all, but when I connect it to my router, it has a weird problem.
My router has two WiFi networks - A WPA2 one and an open one.
When I connect to the open one everything seems OK and the DHCP client works but no packets get in or out of the module.
Looks like this:
[code]>>> w.connect('Public-Internet', '')
f 0, >>> scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
connected with Public-Internet, channel 6
dhcp client start...
cnt
ip:10.0.1.200,mask:255.255.255.0,gw:10.0.1.1
pm open,type:2 0
>>> w.isconnected()
True
>>> w.ifconfig()
('10.0.1.200', '255.255.255.0', '10.0.1.1', '10.0.1.1')
>>> import socket
>>> socket.getaddrinfo('google.com', 80)
OSError: -2[/code]
When I connect to the WPA2 network, it doesn't even really connect, even though the router logs a connection attempt:
[code]>>> w.connect('Zeev', 'asdfqwer')
f r0, >>> scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 2
cnt
pm open,type:2 0
>>> w.isconnected()
False
>>> w.ifconfig()
('0.0.0.0', '0.0.0.0', '0.0.0.0', '10.0.1.1')
OSError: -2
[/code]
Anyone has any ideas? I tried everything. Erased and reflashed several times with --flash_size=32m, changed MTU, channel and encryption settings on the router. I'm stumped.
Thanks for any help.
zeevro
Re: ESP-12F won't connect to MikroTik 951-2n
Post by zeevro » Wed May 11, 2016 7:57 am
No-one has any ideas whatsoever?
Re: ESP-12F weird WiFi issue
Post by deshipu » Wed May 11, 2016 6:06 pm
The only idea I have is to try connecting with something that can collect proper logs (a Linux box), to your network and your neighbour's, and then compare the logs to see what the differences are.
Also check the logs on the router side.
zeevro
Post by zeevro » Wed May 11, 2016 7:40 pm
As it turns out, the ESP thinks that both networks are open, even though one of them (Zeev) is WPA2-encrypted:
(b'Zeev', b'L^\x0c#z\xb1', 6, -40, 0, 0)
(b'Public-Internet', b'N^\x0c#z\xb1', 6, -40, 0, 0)
Does this help?
zeevro
Post by zeevro » Wed May 11, 2016 8:05 pm
The problem was my AP supported TKIP as a possible encryption option. TKIP, as it turns out, is obsolete. Turned that off and the ESP works.
Post by deshipu » Wed May 11, 2016 10:09 pm
Awesome! Thanks for posting the answer, that may help people with similar problems in the future.
platforma
Post by platforma » Thu May 12, 2016 2:19 pm
Might be worth adding this to the FAQ as well.
