[Huzzah Feather] Can't get WiFi connection
SergioDeNice
Post by SergioDeNice » Tue May 10, 2016 9:44 pm
I've just tried to get MicroPython running on my board :
C:\Python27\Scripts>esptool.py --port COM43 erase_flash
esptool.py v1.0.1
Connecting...
C:\Python27\Scripts>esptool.py --port COM43 --baud 115200 write_flash --flash_si
ze=8m 0 D:\Downloads\esp8266-2016-05-03-v1.8.bin
esptool.py v1.0.1
Connecting...
Erasing flash...
Took 2.25s to erase flash block
Wrote 494592 bytes at 0x00000000 in 48.0 seconds (82.4 kbit/s)...
Leaving...
And then I can't see any ESSID to connect to. Any thoughts?
TIA
Serge
Re: [Huzzah Feather] Can't get WiFi connection
Post by deshipu » Tue May 10, 2016 10:16 pm
You have to reset the board afterwards. Also, computers often cache the list of wifi networks, so it may take a while for the new SSID to appear. Have you tried to connect to the REPL on the serial connection?
Post by Roberthh » Wed May 11, 2016 5:20 am
The latest version does not start webrepl in boot py any more. You have to start it manuslly or change boot.py.
torwag
Post by torwag » Thu May 12, 2016 8:25 am
Just for people looking here, as it was said, to use the webrepl you have to activate it first:
import webrepl
webrepl.start()
Either in repl-mode or add this to boot.py
SergioDeNice
Post by SergioDeNice » Thu May 12, 2016 8:19 pm
Resetting the board did the trick. I would have thought unplugging and replugging it would do.
