Besides my HDC1008 sensor on I2C (with pullup-resistors) there is only the following additional circuitry. I have not yet built in logic-level mosfets to cut the power supply for the voltage divider and the I2C bus due to the missing through-hole parts and understanding how to identify them in the electronic shops. I think those should solve these issues, right? Can you give me an advice where to find the p-channel mosfet Pythoncoder used in the fantastic documentation of his project?
Another interesting suggestion is an analogue switch, which i also have not found as through-hole part yet. Do you have some advice to this?
This is my simple high-resistance voltage divider to take the battery voltage down into the 0-1 volt range for the ADC pin:
o V_Bat
10M | |
o--------o-----o ADC-Pin
2M | | --- 0.1µF
o--------'
GND
