Esp8266 firmware precompiled
I am not able to compile firmware for micrp python on esp8266 ( beginner )
Is somewhere a compiled version or someone could send it to me ?
Thank you
Salutations
Thank you
Salutations
Re: Esp8266 firmware precompiled
Hi, welcome to the forums.
The precompiled binaries available for the Kickstarter backers. If you backed the project, you should have received an e-mail with them. If you did not, you can still follow the instructions in the github repository and build your own version -- it's all open source after all.
You might also search this forum for the unofficial daily builds that people have made available.
you might want to have a look at this post: http://forum.micropython.org/viewtopic. ... 547#p10512
Thank you all ... mc esp8266 works ok.
Salutations
Salutations
Will the precompiled versions be available to non-backers at any point? Unfortunately, I wasn't able to back the project while it was in Kickstarter, and I completely understand that backers are first (as they should be).
Precompiled binaries were considered alpha and are released to backers for testing. Although github master is being brought forward all the time to incorporate the alpha features over time, so if you want just "a binary" to flash you module and start playing with the existing features, this is available to everyone and you can build micropython from github repository.
@jcue
I have found a compiled version here http://www.kaltpost.de/~wendlers/micropython/
Thank to this nice person I can play with micropython esp8266
I wish I could compile it by myself but I haven't found a good tutorial ... just some information written by experts
I don't give up ....... I will try another time ......
Salutations
@jcue
Salutations
Re: RE: Re: Esp8266 firmware precompiled
[quote="Asturias"]Hello,
@jcue
I have found a compiled version here [url]http://www.kaltpost.de/~wendlers/micropython/[/url]
Thank to this nice person I can play with micropython esp8266 :)
I wish I could compile it by myself but I haven't found a good tutorial ... just some information written by experts :)
Salutations[/quote]
Nice... Thank you very much. I'll try this out ASAP.
Sent from my SAMSUNG-SM-G920A using Tapatalk
@jcue
Salutations[/quote]
[quote="platforma"]Precompiled binaries were considered alpha and are released to backers for testing. Although github master is being brought forward all the time to incorporate the alpha features over time, so if you want just "a binary" to flash you module and start playing with the existing features, this is available to everyone and you can build micropython from [url=https://github.com/micropython/micropython]github repository[/url].[/quote]
Thank you for the info.. Much appreciated. I'll try my hand at building it myself.
Please avoid excessive overquoting. The official built procedure is describe at http://forum.micropython.org/viewtopic.php?f=16&t=1689 . Any other process is UNSUPPORTED.
Awesome MicroPython list
