access via SSH?
pythonista
access via SSH?
Post by pythonista » Mon Jun 13, 2016 8:30 pm
Is it possible to connect remotely over wifi (using SSH) to my ESP8266 running Micropython? 8-)
torwag
Re: access via SSH?
Post by torwag » Mon Jun 13, 2016 8:43 pm
No, that would require to run an ssh server on the esp8266. For the ssh server it would need some more dependencies, it would need a shell and it would need some sort of underlyimg OS to manage all this in some way. etc. Micropython is not an OS (yet ;) ). Thus it is unlikely that something like ssh will ever work. If you work with micropython you need to think about bare metal microcontrollers which execute a single python program.
pythonista
Re: access via SSH?
Post by pythonista » Mon Jun 13, 2016 8:47 pm
understand totally, but I am so delighted with MicroPython that I think that remote access is the only thing missing for total happiness :))
at least telnet (if openssl is too complicated for now) would be nice... (and enable to thinker with micropython without wires...)
markxr
Re: access via SSH?
Post by markxr » Mon Jun 13, 2016 9:52 pm
Telnet is probably do-able with the current infrastructure in Micropython. The existing remote shell is not too different from telnet.
torwag
Re: access via SSH?
Post by torwag » Mon Jun 13, 2016 10:20 pm
do you know about webrepl?
pythonista
Re: access via SSH?
Post by pythonista » Mon Jun 13, 2016 11:09 pm
yes, tried to import it but cannot see that it binds/starts listening?
dhcp client start...
Performing initial setup
  File "_boot.py", line 9, in <module>
  File "inisetup.py", line 37, in setup
  File "inisetup.py", line 9, in wifi
OSError: can't set AP config
could not open file 'boot.py' for reading
could not open file 'main.py' for reading
#4 ets_task(40100350, 3, 3fff6350, 4)
MicroPython v1.8.1-35-gdeaf071 on 2016-06-12; ESP module with ESP8266
>>> ip:192.168.6.232,mask:255.255.255.0,gw:192.168.60.1
import webrepl
>>> pm open,type:2 0
Re: access via SSH?
Post by deshipu » Tue Jun 14, 2016 9:36 am
you need webrepl.start()
pythonista
Re: access via SSH?
Post by pythonista » Wed Jun 15, 2016 10:11 pm
Thank you, work like a charm...
connects via web client, but it always ask for a password setup (first time setup)...
any idea why it don't save settings?
here is message from console while connecting via web script...
  File "webrepl_setup.py", line 71, in handle_conn
OSError: [Errno 19] ENODE
Re: access via SSH?
Post by deshipu » Thu Jun 16, 2016 8:13 am
Can you run "import port_diag" on your board and paste here the results?
pythonista
Re: access via SSH?
Post by pythonista » Thu Jun 16, 2016 6:21 pm
yes, here is it:
>>> import port_diag
FlashROM:
Flash ID: 1640e0 (Vendor: e0 Device: 4016)
Flash bootloader data:
Byte @2: 00
Byte @3: 40 (Flash size: 4MB Flash freq: 40MHZ)
Networking:
STA ifconfig: ('192.168.60.232', '255.255.255.0', '192.168.60.1', '192.168.60.1')
AP ifconfig: ('0.0.0.0', '0.0.0.0', '0.0.0.0', '192.168.60.1')
Free WiFi driver buffers of type:
0: 8
1: 0
2: 8
3: 4
4: 7
lwIP PCBs:
Active PCB states:
Listen PCB states:
TIME-WAIT PCB states:
