Re: access via SSH?
Posted: Thu Jun 16, 2016 7:29 pm
Thank you, that looks good, still no idea what might be wrong.
Please see the new forum at
https://forum.micropython.org/
pythonista wrote:yes, tried to import it but cannot see that it binds/starts listening?
dhcp client start... Performing initial setup Traceback (most recent call last): File "_boot.py", line 9, in <module> File "inisetup.py", line 37, in setup File "inisetup.py", line 9, in wifi OSError: can't set AP config could not open file 'boot.py' for reading could not open file 'main.py' for reading #4 ets_task(40100350, 3, 3fff6350, 4) MicroPython v1.8.1-35-gdeaf071 on 2016-06-12; ESP module with ESP8266 Type "help()" for more information. >>> ip:192.168.6.232,mask:255.255.255.0,gw:192.168.60.1 import webrepl >>> pm open,type:2 0
MicroPython v1.8.1-55-g332545b on 2016-06-16; ESP module with ESP8266
File "webrepl_setup.py", line 71, in handle_conn
OSError: [Errno 19] ENODE
with open("port_config.py", "w") as f:
f.write("WEBREPL_PASS = %r\n" % passwd1.decode("ascii"))
>>> import os
>>> os.listdir()
OSError: [Errno 19] ENODEV
You should look into vfs, help(vfs) which should show you at least _boot.pypythonista wrote: ...
>>> import os >>> os.listdir() Traceback (most recent call last): File "<stdin>", line 1, in <module> OSError: [Errno 19] ENODEV >>>
These are golden words and exactly mirror outlook of the maintainers (well, mine for sure). SSL/TLS is pretty tricky thing, and even big boxes have problems with it, remember or Heartbleed, or at my dayjob, we had intermittent TLS failures for last 2 months and suspected everything up to hardware failure (somewhere at the cloud provider, as customary nowadays). Turned out it's a software issue reported some 5 years ago and marked as "Wontfix": https://bugs.launchpad.net/ubuntu/+sour ... bug/795355 . So again, if "big iron" has problems with it, just imagine what problems small embedded systems have. We provide basic SSL support which works for basic things. I'm ready to go as far as possible beyond that, up to developing own TLS implementation. But before going that deep (can easily take half a year), we're going to make many useful things to be available which should work pretty well in your local network, protected by WPA.jms wrote:
In fact the same could be said of TLS/SSL and using external cloud services. It's much easier to talk to something on the local network without it.
Jon
