Does big number calculate has bug in ESP8266 board? I calculate 44*55 in ESP8266 and STM32L476DISC, the result is different.
In ESP8266:
MicroPython v1.8.1-81-g6b088a6 on 2016-06-20; ESP module with ESP8266
>>> 44**55
24541279788272642710876651734897621278680174612083477162383185691311496161944044
In STM32L476DISCO:
MicroPython v1.8.1 on 2016-06-12; L476-DISCO with STM32L476
>>> 44**55
24541279788272642710876651734897621278680174612083477162383185691311496161944046
94280372224
Re: Does big number calculate has bug in ESP8266 board?
When I use hypertrm in windows it may cuase this porblem, but when I use putty, result is correctly.
My guess (and it is just a guess: I don't use Windows) is that it's a terminal artefact. It looks to me as if Hyperterm is set to 80 columns and isn't handling line wrap. It displays 80 characters correctly, but then puts subsequent characters in the rightmost column, repeatedly overwriting column 80. Compare your erroneous result with the correct result from CPython and ESP8266.
Line 1: erroneous result
Line 2: CPython on Linux
Line 3: ESP8266 via Miniterm on Linux
Both are identical up to column 79. Your erroneous result has the final digit of the correct result in column 80.
2454127978827264271087665173489762127868017461208347716238318569131149616194404694280372224
