I am been working through small issue setting up a dev environment for the ESP8266 and micropython. After setting up a clean environment I ran through the processes for the open SDK and when getting to the building micropython for the ESP8266 (after make axlts) I got this error, which is something I do not believe I have seen during all my other searches on using micropython for the ESP8266. This seems to be localized to the micropython portion of the build and I will continue to look into this further but thought others might be able to help me deal with this quickly as well as help out others that might find this.
python ../py/makeversionhdr.py build/genhdr/mpversion.h
MPY modules/flashbdev.py
mkdir -p build/modules/
../mpy-cross/mpy-cross -o build/modules/flashbdev.mpy -s flashbdev.py modules/flashbdev.py
make: ../mpy-cross/mpy-cross: Command not found
Makefile:175: recipe for target 'build/modules/flashbdev.mpy' failed
make: *** [build/modules/flashbdev.mpy] Error 127
