The DHT12 is a newer version of the DHT11 sensor, which adds I2C and improved accuracy.
It's backwards compatible with the DHT11 one wire interface when you tie SCL to GND.
The following works on my Arduino Uno:
byte address = 0x5C
Wire.beginTransmission(address);
Wire.write(0);
Wire.endTransmission();
Wire.requestFrom(address, 5);
a[0] = Wire.read();
a[1] = Wire.read();
a[2] = Wire.read();
a[3] = Wire.read();
a[4] = Wire.read();
import ustruct
from machine import I2C, Pin
i2c = I2C(scl=Pin(5), sda=Pin(4), freq=400000)
i2c.scan()
[92]
address = 92
register = 0
i2c.start()
i2c.write(ustruct.pack('<BH', address, register))
ustruct.unpack('BBBBB', i2c.readfrom(address,5))
I've tried i2c.readinto(buf), i2c.readfrom(92, 5), i2c.readfrom_mem(92, 0, 5) and a bunch of other combinations.
Doesn't appear to be a memory mapping i2c sensor, instead more like RTC1307 multi-byte read.
Confusing part is the docs say the device address is 0xB8 (184), yet it is showing up in i2c.scan() as 92 (0x5C).
92 << 1 == 184.
I've went through these and tons of repos found on GitHub and BitBucket, and still can't get it working!
https://github.com/micropython/micropython/issues/2073
https://github.com/micropython/micropython/issues/1948
viewtopic.php?t=872
https://docs.python.org/3/library/struct.html
The Google-translated datasheet:
https://drive.google.com/file/d/0B1LcZm ... gxRjA/view
There are supposed to be 5 bytes returned:
0x00 = Humidity
0x01 = Humidity decimal places
0x02 = Temperature
0x03 = Temperature decimal places
0x04 = Checksum (sum 0x00,0x01,0x02,0x03)
Arduino example returns data like this:
45,6,24,0,75 - which means 45.6 %RH, 24.0 deg C, (valid checksum 45+6+24+0=75)
45,6,23,9,83 - which means 45.6 %RH, 23.9 deg C, (valid checksum 45+6+23+9=83)
45,7,23,9,84 - which means 45.7 %RH, 23.9 deg C, (valid checksum 45+7+23+9=84)
Little help?
