UMQTT: Achieving a robust connection
Post by pythoncoder » Fri Jul 22, 2016 10:31 am
In practice continuous WiFi connectivity cannot be guaranteed. The following code recovers after a WiFi outage. Note that failed publications are lost, but it would be straightforward to queue these if the application required it.
Comments, suggestions or improvements welcome.
import ubinascii
from simple import MQTTClient
from machine import Pin, unique_id
SERVER = "192.168.0.23"
CLIENT_ID = ubinascii.hexlify(unique_id())
TOPIC = b"huzzah"
def main(server=SERVER):
    client = MQTTClient(CLIENT_ID, server)
    client.connect()
    print("Connected to %s, waiting for timer" % server)
    fail = False
    count = 0
            count += 1
            time.sleep_ms(5000)
            if fail: # WiFi was down
                    client.connect()
                    fail = False
                except OSError: # WiFi is still down
                    print('Reconnect fail')
                client.publish(TOPIC, 'count {}'.format(count).encode('UTF8'))
                print('Publish') # Simplistic code loses messages while WiFi is down
                fail = False
            except OSError:
                print('Publish fail')
                fail = True
    finally: # if code fails or is interrupted
        client.disconnect()
turutupa
Re: UMQTT: Achieving a robust connection
Post by turutupa » Wed Mar 04, 2020 8:55 am
Is there a similar approach for a robust mqtt subscription with esp8266?? So far I manage to keep subscribed to Adafruit for around 2 days and then it simply stops working.. I've been thinking about setting my esp8266 to automatically reset once per day.. that might help.
