I just installed the binary release esp8266-2016-07-22-v1.8.2-29-gb652ee7.bin with esptool.py on an wemos d1 mini.
Fist I erase the the flash, then I use this:
C:\Python27\Scripts>..\python esptool.py -p COM4 write_flash 0x0000000 esp8266-2016-07-22-v1.8.2-29-gb652ee7.bin
esptool.py v1.1
Connecting...
Running Cesanta flasher stub...
Flash params set to 0x0000
Writing 512000 @ 0x0... 512000 (100 %)
Wrote 512000 bytes at 0x0 in 48.4 seconds (84.7 kbit/s)...
Leaving...
After resetting the blue LED flashes very fast and a serial connect gives the following message:
"▒▒g▒▒▒▒crc▒▒c쇜▒▒d▒▒▒▒xbd`▒▒d▒Fatal exception 28(LoadProhibitedCause):
epc1=0x4024ff23, epc2=0x00000000, epc3=0x00000000, excvaddr=0x02050504, depc=0x00000000
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x40100000, len 30804, room 16"
I thougth the hardware may be broken but after flashing my Arduino MQTT demo, everithing works fine.
Any ideas on that?
Thank in advance
Bernd
Micropython on a WeMos Di Mini
Re: Micropython on a WeMos Di Mini
I successfully flashed this build to three WeMos D1 Mini's today, using the following incantation (under Linux):
Clearly you'll need to change the port designation, but give it a try. Press the reset button after flashing.
esptool.py -p /dev/ttyUSB0 erase_flash
esptool.py -p /dev/ttyUSB0 write_flash -fm dio -fs 32m -ff 40m 0x00000 esp8266-2016-07-22-v1.8.2-29-gb652ee7.bin
My experience is the Windows GUI tool works and esptool doesn't.
I fash from Windows. What is the name of the Windows GUI you mention?
Finally got it. Under Windows use nodemcu-flasher (https://github.com/nodemcu/nodemcu-flasher) under Win32 (or Win64)/Release
Under "Operation" set your COM-Port, under "Config" set the path to the binary at 0x00000 under advanced set:
baudrate to 921600,
flash size to 4MByte,
FlashSpeed to 80MHz
SPI Mode to DIO
Under Operation Click "Flash", wait a bit. Press the rest button.
After flashing I use putty with connection type serial and speed 115200. Afer the connection to got a black screen, press enter and the pyton prompt appears
Bernd
baudrate to 921600,
FlashSpeed to 80MHz
SPI Mode to DIO
Bernd
sorry for beeing so fast-paced in the morning. My coffee is a bit strong
I totally miss that there was another post, sorry.
When you set the correct flash parameter like ..\python esptool.py --port COM4 write_flash -fm dio -fs 32m -ff 40m 0x0000000 esp8266-2016-07-22-v1.8.2-29-gb652ee7.bin everything works fine with the esptool.py under Windows.
Bernd
Bernd
Does the Windows CH340G allow you to upload at 921600?
On OSX the driver won't let you upload any faster than 230400
