Hello i need to have an ssl connection to an Imap server.
I'm stuck, when i wrap my socket it raise an error on the esp board, (it does work on the wipy)
(Error:ssl_handshake status: -256,ErroNo: 5)
Is the ussl equaly implemented on the wipy and esp board?
Christian
ussl, ssl_handshake status: -256,ErroNo: 5
Re: ussl, ssl_handshake status: -256,ErroNo: 5
The small SSL implementation is minimal and won't talk to things that are trying to be secure. I think you have answered your own question regarding equality.
You could probably enable debug somewhere or dig around in the code and find out exactly what but you're very unlikely to be able to fix it and if you did fix it chances are it would break again.
As I have said elsewhere use the ESP8266 to talk to a server _you_ control using the simplest possible protocol (I suggest UDP, not TCP and certainly not HTTP) and forget SSL.
