I/O expander
joehunt588
I/O expander
Post by joehunt588 » Fri Jul 29, 2016 7:40 am
Hai guy can suggest any working i/o expander for esp8266 that using i2c?
im currently struggle using i2c for mcp23017
[code]
i2c = I2C(scl=Pin(5), sda=Pin(4), freq=100000)
#DEVICE = 0x20 # Device address (A0-A2)
#IODIRA = 0x00 # Pin direction register
#OLATA = 0x14 # Register for outputs
#GPIOA = 0x12 # Register for inputs
#register addr
addr = bytearray([0x00,0x00])
i2c.writeto(0x20, addr) <--- error Traceback (most recent call last):
TypeError: object with buffer protocol required
[/code]
Please help me using mcp23017 on esp8266 (previous using code in rpi) or suggest easy way in using i/o expander
<link>https://cdn-shop.adafruit.com/datasheet ... .pdf</link>
Re: I/O expander
Post by pythoncoder » Sat Jul 30, 2016 5:00 am
I suspect the cause is out of date firmware. That error should not occur. Here I get
OSError: I2C bus error
which is to be expected as I haven't got the hardware connected. It is accepting the bytearray and trying to write to the nonexistent kit.
mcauser
Re: I/O expander
Post by mcauser » Sat Jul 30, 2016 1:21 pm
I'm using a PCF8574 "backpack" with a 1602 LCD and a WeMos D1 mini.
They are also sold as a regular I/O module, without 16 pin LCD specific header.
http://www.aliexpress.com/item/PCF8574- ... 58823.html
mcauser
Re: I/O expander
Post by mcauser » Sat Jul 30, 2016 1:23 pm
Try dropping the I2C frequency and different pull-up resistor values.
I was unable to get an I2C temperature sensor working higher than 50,000 without I2C bus error messages.
shaoziyang
Re: I/O expander
Post by shaoziyang » Sat Jul 30, 2016 2:22 pm
Good idea.
joehunt588
Re: I/O expander
Post by joehunt588 » Mon Aug 01, 2016 4:39 pm
Hi pythoncoder
i using firmware micropython 1.8.2,what version you use?
joehunt588
Re: I/O expander
Post by joehunt588 » Tue Aug 02, 2016 10:34 am
Hi mcauser,
how can i scan i2c port? when i using i2c.scan() it show result in list [4,8 -> 41],by default it 0x20.
can you share me code for PCF8574A python ,i now order the chip :D
mcauser
Re: I/O expander
Post by mcauser » Tue Aug 02, 2016 1:42 pm
i2c.scan() returns results in decimal. 0x20 == 32.
If you are seeing a bunch of unrelated scan results, you may be missing pull-up resistors.
I saw that when I was working with a DHT12 sensor. Added pull-ups and scan then returned a single item.
Here is an example of using WeMos D1 mini + PCF8574 I2C expander + 1602 HD44780 character LCD:
https://github.com/dhylands/python_lcd/pull/2
joehunt588
Re: I/O expander
Post by joehunt588 » Tue Aug 02, 2016 3:41 pm
Hi mcauser
thank you for the code appreciate :D .
may i know where do i need put resistor?do i need to put resistor for SDA and SCL line?Sorry for my noob question do you have schematic where i can follow to put the pull out resistor?
warren
Re: I/O expander
Post by warren » Tue Aug 02, 2016 5:30 pm
joehunt588 wrote:Hi mcauser
Yes, on both.
The optimal value for the resistors depends on clock speed and cable type.
If you intend to have any I2C sensors further than a few tens of cm away from the ESP, you may need to reduce the clock speed. In my tests with BMP280s, reducing the clock speed to 10kHz introduces only a slight delay.
There are a couple of helpful links about I2C resistances here:
http://dsscircuits.com/articles/effects ... -resistors
and
https://rheingoldheavy.com/i2c-pull-resistors/
