# configuration written to .config
Initially reported by: Max Filippov <jcmvbkbc@gmail.com>
URL: http://www.esp8266.com/viewtopic.php?f=9&t=224
WARNING! This sample may enable experimental features.
Please be sure to review the configuration prior
to building and using your toolchain!
Now, you have been warned!
Now configured for "xtensa-lx106-elf"
make[2]: Leaving directory `/mnt/c/Users/Pete/Documents/esp8266/build/esp-open-sdk/crosstool-NG'
sed -r -i.org s%CT_PREFIX_DIR=.*%CT_PREFIX_DIR="/mnt/c/Users/Pete/Documents/esp8266/build/esp-open-sdk/xtensa-lx106-elf"% .config
sed -r -i s%CT_INSTALL_DIR_RO=y%"#"CT_INSTALL_DIR_RO=y% .config
cat ../crosstool-config-overrides >> .config
./ct-ng build
make[2]: Entering directory `/mnt/c/Users/Pete/Documents/esp8266/build/esp-open-sdk/crosstool-NG'
[INFO ] Performing some trivial sanity checks
[INFO ] Build started 20160818.214952
[INFO ] Building environment variables
[INFO ] =================================================================
[INFO ] Retrieving needed toolchain components' tarballs
[INFO ] Retrieving needed toolchain components' tarballs: done in 166.37s (at 03:02)
[INFO ] Extracting and patching toolchain components
[INFO ] Extracting and patching toolchain components: done in 450.18s (at 10:33)
[INFO ] Installing ncurses for build
[INFO ] Installing ncurses for build: done in 59.94s (at 11:33)
[INFO ] Installing GMP for host
[INFO ] Installing GMP for host: done in 152.03s (at 14:05)
[INFO ] Installing MPFR for host
[ERROR] make[3]: *** [/mnt/c/Users/Pete/Documents/esp8266/build/esp-open-sdk/crosstool-NG/.build/src/mpfr-3.1.3/aclocal.m4] Error 127
[ERROR]
[ERROR] >>
[ERROR] >> Build failed in step 'Installing MPFR for host'
[ERROR] >> called in step '(top-level)'
[ERROR] >>
[ERROR] >> Error happened in: CT_DoExecLog[scripts/functions@257]
[ERROR] >> called from: do_mpfr_backend[scripts/build/companion_libs/110-mpfr.sh@149]
[ERROR] >> called from: do_mpfr_for_host[scripts/build/companion_libs/110-mpfr.sh@104]
[ERROR] >> called from: do_companion_libs_for_host[scripts/build/companion_libs.sh@36]
[ERROR] >> called from: main[scripts/crosstool-NG.sh@646]
[ERROR] >>
[ERROR] >> For more info on this error, look at the file: 'build.log'
[ERROR] >> There is a list of known issues, some with workarounds, in:
[ERROR] >> 'share/doc/crosstool-ng/crosstool-ng-1.22.0-55-gecfc19a/B - Known issues.txt'
[ERROR]
[ERROR] (elapsed: 14:31.90)
[14:34] / make[2]: *** [build] Error 2
make[1]: *** [_toolchain] Error 2
make[1]: Leaving directory `/mnt/c/Users/Pete/Documents/esp8266/build/esp-open-sdk/crosstool-NG'
make: *** [/mnt/c/Users/Pete/Documents/esp8266/build/esp-open-sdk/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc] Error 2
[EXTRA] Building MPFR
[DEBUG] ==> Executing: '/usr/bin/make' '-j5' '-l'
[ALL ] make[3]: Entering directory `/mnt/c/Users/Pete/Documents/esp8266/build/esp-open-sdk/crosstool-NG/.build/xtensa-lx106-elf/build/build-mpfr-host-x86_64-build_pc-linux-gnu'
[ALL ] CDPATH="${ZSH_VERSION+.}:" && cd /mnt/c/Users/Pete/Documents/esp8266/build/esp-open-sdk/crosstool-NG/.build/src/mpfr-3.1.3 && /bin/bash /mnt/c/Users/Pete/Documents/esp8266/build/esp-open-sdk/crosstool-NG/.build/src/mpfr-3.1.3/missing aclocal-1.15 -I m4
[ALL ] /mnt/c/Users/Pete/Documents/esp8266/build/esp-open-sdk/crosstool-NG/.build/src/mpfr-3.1.3/missing: line 81: aclocal-1.15: command not found
[ALL ] WARNING: 'aclocal-1.15' is missing on your system.
[ALL ] You should only need it if you modified 'acinclude.m4' or
[ALL ] 'configure.ac' or m4 files included by 'configure.ac'.
[ALL ] The 'aclocal' program is part of the GNU Automake package:
[ALL ] <http://www.gnu.org/software/automake>
[ALL ] It also requires GNU Autoconf, GNU m4 and Perl in order to run:
[ALL ] <http://www.gnu.org/software/autoconf>
[ALL ] <http://www.gnu.org/software/m4/>
[ALL ] <http://www.perl.org/>
[ALL ] make[3]: Leaving directory `/mnt/c/Users/Pete/Documents/esp8266/build/esp-open-sdk/crosstool-NG/.build/xtensa-lx106-elf/build/build-mpfr-host-x86_64-build_pc-linux-gnu'
[ERROR]
Any clues?
