I flashed esp8266-20160809-v1.8.3.bin to my esp8266-01.
When I boot the esp8266 now I get an error (full output below):
File "boot.py", line 5, in <module>
File "webrepl.py", line 6, in <module>
File "websocket_helper.py", line 1
SyntaxError: invalid syntax
Can somebody please tell me what the problem is? A syntax-error in boot.py?
I just flashed the .bin-file. I used the --verify-option and got an OK.
It seems I cannot use machine.xxx objects. Webrepl seems not to be working too.
I executed
>>> esp.check_fw()
md5: 66cd5e59c4f2236a5bc3b7c97789adc3
False
That function unfortunately is not documented in https://docs.micropython.org/en/latest/ ... y/esp.html but 'False' is probably bad?
Thank you!
Output at boot:
������������������������������������������l)
h, v = [x.strip() for x in l.split(b":", 1)]
if DEBUG:
print((h, v))
if h == b'Sec-WebSocket-Key':
webkey = v
if not webkey:
raise OSError("Not a websocket request")
if DEBUG:
print("Sec-WebSocket-Key:", webkey, len(webkey))
d = hashlib.sha1(webkey)
d.update(b"258EAFA5-E914-47DA-95CA-C5AB0DC85B11")
respkey = d.digest()
respkey = binascii.b2a_base64(respkey)[:-1]
if DEBUG:
print("respkey:", respkey)
sock.send(b"""\
HTTP/1.1 101 Switching Protocols\r
Upgrade: websocket\r
Connection: Upgrade\r
Sec-WebSocket-Accept: """)
sock.send(respkey)
sock.send("\r\n\r\n")
# Very simplified client handshake, works for MicroPython's
# websocket server implementation, but probably not for other
# servers.
def client_handshake(sock):
cl = sock.makefile("rwb", 0)
cl.write(b"""\
GET / HTTP/1.1\r
Host: echo.websocket.org\r
Sec-WebSocket-Key: foo\r
\r
l = cl.readline()
# print(l)
while 1:
l = cl.readline()
if l == b"\r\n":
break
# sys.stdout.write(l)
could not open file 'main.py' for reading
MicroPython v1.8.3-10-g2401581 on 2016-08-09; ESP module with ESP8266
SyntaxError at boot with esp8266-20160809-v1.8.3.bin
Re: SyntaxError at boot with esp8266-20160809-v1.8.3.bin
False is indeed bad and indicates that the firmware image is invalid. Does your device have sufficient flash to accommodate it?
I had the same error when I switched from some older version of 1.8.2 to 1.8.3. I was also using something different at that time, not esptool. Cleaning flash and flashing the image with esptool solved the problem for me, so try running these 2 commands first (and replace the name of the image if needed):
esptool.py --port COM3 erase_flash
esptool.py --port COM3 --baud 460800 write_flash --flash_size=8m 0 esp8266-20160809-v1.8.3-release.bin
Fortunately, everything is documented in troubleshooting section: http://docs.micropython.org/en/latest/e ... n-problemsThat function unfortunately is not documented in https://docs.micropython.org/en/latest/ ... y/esp.html but 'False' is probably bad?
Awesome MicroPython list
My ESP8266 should have 512KB. The 1.8.3.bin-file has 558,8KB, so maybe it is to large.
I now flashed 1.8.2.bin which is 507,6KB. It seems to be working so far...
