WeMos D1 Mini Pro 16MB
Re: WeMos D1 Mini Pro 16MB
Post by deshipu » Wed Sep 14, 2016 7:36 am
So my board arrived and it indeed is a 4-layer PCB. I will post photos and test results shortly.
Post by deshipu » Wed Sep 14, 2016 8:40 am
OK, so here are some first simple tests.
I have flashed the latest master of MicroPython and this module, and it seems to work fine (no surprises there).
As you can guess per https://github.com/micropython/micropython/issues/2335, it doesn't actually see 16MB of flash memory. It sees it as 1MB.
Info from port_diag:
>>> import port_diag
FlashROM:
Flash ID: 1840ef (Vendor: ef Device: 4018)
Flash bootloader data:
Byte @2: 02
Byte @3: 20 (Flash size: 1MB Flash freq: 40MHZ)
Firmware checksum:
md5: 81b350413dfda43fdce2fe7dc40e727e
True
Networking:
STA ifconfig: ('0.0.0.0', '0.0.0.0', '0.0.0.0', '208.67.222.222')
AP ifconfig: ('192.168.4.1', '255.255.255.0', '192.168.4.1', '208.67.222.222')
Free WiFi driver buffers of type:
0: 8
1: 0
2: 8
3: 4
4: 7
lwIP PCBs:
Active PCB states:
Listen PCB states:
TIME-WAIT PCB states:
Some photos:
photoacoustic
Post by photoacoustic » Thu Sep 29, 2016 8:54 am
Dear all,
Thanks for these post.
I am preparing a workshop in Africa (Senegal, Saint Louis). I will use the nice materials provide by deshipu! Thanks
so with the apparition of the pro version, I hesitate between WeMos D1 Mini vs WeMos D1 Mini pro.
pro version --> new serial-USB chip driver seems to be more easy to install and to find, but with 16 MB flash don't know if a good idea to move now!
Any comments are welcome.
Best regards
Arouna
rcolistete
Post by rcolistete » Sat Oct 08, 2016 12:12 pm
deshipu wrote:I have flashed the latest master of MicroPython and this module, and it seems to work fine (no surprises there).
Any more news about the 16MB of flash being visible using MicroPython on WeMos D1 Mini Pro ?
Post by deshipu » Sat Oct 08, 2016 12:16 pm
I'm sure the issue I linked above will be updated as soon as this is fixed, but I wouldn't hold my breath.
torkinp
Post by torkinp » Tue Apr 03, 2018 5:41 pm
