main.py don't start after poweron
Hello!!!
I'm new here and I've already my first problem. I tried a lot of code snippets and everything is working like expected.
Now I tried create a main.py file, that should start after poweron of the board. ...but it is not working.
Could anybody give me a hint how to do that?
I'm using the development board "Witty Cloud" with the ESP-12F.
Thanks a lot...
Thanks a lot...
Re: main.py don't start after poweron
How did you "create" the file? Perhaps you can walk us through what you have done so far and what output you get, that makes you think it's not working?
Yes, of course...
At first I installed the firmware esp8266-20160901-v1.8.3-81-g9c04ef2.bin and then I create a new boot.py and main.py file with Vi.
here the content of "boot.py":
content of "main.py":
Now I flashed the latest firmware esp8266-20160905-v1.8.3-112-gb4df3e7.bin but main.py is still not running...
What could be the reason for that?
EDIT: It seems that main.py is loaded but main() not executed... Why?
import webrepl
print("boot.py loaded...")
webrepl.start()
import esp
def toggle(p):
p.value(not p.value())
def main():
pin = machine.Pin(2, machine.Pin.OUT)
for i in range(10):
toggle(pin)
time.sleep_ms(500)
if __name__ == 'main':
print("main entered")
esp.osdebug(0)
main()
I think one of the things @platforma was after was how you transferred the two files to the ESP8266. However if it's now working then you've evidently done this successfully
For file transfer I'm using mpfshell.
The problem is, that main.py is loaded but main() not executed... Any idea why???
EDIT: OK, sorry for that stupid question/problem.
wrong:
correct:
wrong:
if __name__ == '__main__':
Just to ask a few simple questions:
Do you see the message printed "main entered", e.g. after reboot with Ctrl-D?
How do you tell that main() is not executed. Did you try a print statement inside main(), just to sort our any connection issue with the LED?
Yes, I see... After fixing the code everything is working like expected.Roberthh wrote:Do you see the message printed "main entered", e.g. after reboot with Ctrl-D?
Not yet, but the code is working now.Roberthh wrote:How do you tell that main() is not executed. Did you try a print statement inside main(), just to sort our any connection issue with the LED?
Thanks a lot for the help!!!
Easy mistake to get caught out on, glad you got it working!
I'm new to ESP & Micropython, I wanted to run micropython code by including it in firmware .....I get following error on powering on NodeMCU.
"could not open file 'main.py' for reading"
I did following
1) Built esp sdk toolchain using documentaion available at
https://learn.adafruit.com/building-and ... d-firmware
2) Created main.py with following code at "/home/vagrant/micropython/esp8266/scripts" on ubuntu VM
3) compiled firmware & copied it to /vagrant folder
4) Flashed the firmware on NodeMCU using esptool.py
I'm not able to find out what went wrong....
pin = machine.Pin(5, machine.Pin.OUT)
for i in range(100):
pin.value(1)
time.sleep(0.25)
pin.value(0)
time.sleep(0.25)
I did following
pin.value(1)
time.sleep(0.25)
pin.value(0)
time.sleep(0.25)
Two questions:
a) How much flash has your device? For a file system, at least 1 MByte is required. You can tell by exectuing from the command line
b) Try to erase the flash before loading micropython. Issue
import port_diag
esptool.py erase_flash
