Static IP Possibility
yeyeto2788
Post by yeyeto2788 » Thu Sep 08, 2016 6:51 pm
Hello all,
I'm building a Temperature and Humidity server that I want to monitor from work but I'm not able to set a static or fixed IP.
Is there a possibility to set Fixed IP on MicroPython for ESP8266? I have found some info but only for the WiPy.
Ohh I almost forgot, I'm running Version 1.8.3 :)
Thanks!
Re: Static IP Possibility
Post by deshipu » Thu Sep 08, 2016 8:11 pm
What did you try already and how it didn't work?
Post by deshipu » Thu Sep 08, 2016 8:16 pm
Looking at the code, you should be able to set the address with network.ifconfig, passing it a tuple of four values: the address, the network mask, the gateway address and the dns server address.
yeyeto2788
Post by yeyeto2788 » Fri Sep 09, 2016 5:40 am
[quote="deshipu"]Looking at the code, you should be able to set the address with network.ifconfig, passing it a tuple of four values: the address, the network mask, the gateway address and the dns server address.[/quote]
You meant something like this:
[code]network.ifconfig ('192.168.1.30', '255.255.255.0', '10.1.1.7', '8.8.8.8')[/code]
Post by deshipu » Fri Sep 09, 2016 8:01 am
Well, the gateway IP usually has to be in the same subnetwork as your normal IP for it to function properly. Otherwise, how it didn't work?
yeyeto2788
Post by yeyeto2788 » Wed Sep 14, 2016 11:05 am
Hello, sorry for the late reply
deshipu wrote:Well, the gateway IP usually has to be in the same subnetwork as your normal IP for it to function properly. Otherwise, how it didn't work?
This is my code to setup the Static IP but it seems not to be working :(
sta_if.active(True)
sta_if.ifconfig('xxx.xxx.xxx.xxx','255.255.255.0','192.168.1.1','xxx.xxx.xxx.xxx')
sta_if.connect('SSID','Password')
This is the error I get when I input the data
  File "<stdin>", line 9, in <module>
TypeError: function expected at most 2 arguments, got 5
It seems to be expecting a str instead of a tuple or a list.
Post by Roberthh » Wed Sep 14, 2016 11:11 am
You have to put the parameters in a tuple:
sta_if.ifconfig(('xxx.xxx.xxx.xxx','255.255.255.0','192.168.1.1','xxx.xxx.xxx.xxx'))
Like shown in the docs.
yeyeto2788
Post by yeyeto2788 » Wed Sep 14, 2016 11:23 am
sta_if.active(True)
It actually worked!!! I re-read the documentation http://docs.micropython.org/en/latest/e ... twork.html and it works :D :D :D :D
The problem was that I had to do it this way:
network.ifconfig(('xxx.xxx.xxx.xxx','255.255.255.0','192.168.1.1','xxx.xxx.xxx.xxx'))
Note the double parenthesis on the code.
Why is this? maybe is a silly question but I don't get it. :(
fdufnews
Post by fdufnews » Wed Sep 14, 2016 11:44 am
As said in the documentation,
To set the above values, pass a 4-tuple with the required information.
So
is a 4-tuple.
Maybe you should look here http://www.tutorialspoint.com/python/python_tuples.htm
Post by pythoncoder » Thu Sep 15, 2016 8:05 am
a = (1,2,3)
creates a 3-tuple (a tuple with 3 elements). If we have a function which expects a 3-tuple as an argument we can call it with either of:
func(a)
func((6,7,8))
