Module for Ultrasonic sensor (HC-SR04)
orsisam
Re: Module for Ultrasonic sensor (HC-SR04)
Post by orsisam » Tue Sep 27, 2016 1:23 am
Thanks for pythoncoder to help me understood the code.
Thanks for skgsergio to share the code on Github: https://github.com/skgsergio/MicropythonLibs
Finally yesterday I success to modify the code to work with esp8266, I am testing using Wemos D1 Mini board. So, maybe it will compatible with all esp8266 board too. Here the code, hope it will usefull for other:
# Ultrasonic library for MicroPython's pyboard.
# Compatible with HC-SR04 and SRF04.
# Copyright 2014 - Sergio Conde Gómez <skgsergio@gmail.com>
# Improved by Mithru Vigneshwara
# Modified by orsisam <orsi.amax@gmail.com> for
# compatibility with esp8266
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program.  If not, see <http://www.gnu.org/licenses/>.
#import pyb
class Ultrasonic:
    def __init__(self, tPin, ePin):
        # WARNING: Don't use PA4-X5 or PA5-X6 as echo pin without a 1k resistor (Attention for PyBoard)
        self.triggerPin = tPin
        self.echoPin = ePin
        # Init trigger pin (out)
        self.trigger = machine.Pin(self.triggerPin)
        self.trigger.init(machine.Pin.OUT, pull=None, value=0)
        #self.trigger.PULL_DOWN()
        # Init echo pin (in)
        self.echo = machine.Pin(self.echoPin)
        self.echo.init(machine.Pin.IN, pull=None)
    def distance_in_inches(self):
        return (self.distance_in_cm() * 0.3937)
    def distance_in_cm(self):
        start = 0
        end = 0
        # Create a microseconds counter.
        #micros = pyb.Timer(2, prescaler=83, period=0x3fffffff)
        #micros.counter(0)
        # Send a 10us pulse.
        self.trigger.high()
        time.sleep_us(10)
        #pyb.udelay(10)
        self.trigger.low()
        # Wait 'till whe pulse starts.
        while self.echo.value() == 0:
            start = time.ticks_us()
        # Wait 'till the pulse is gone.
        while self.echo.value() == 1:
            end = time.ticks_us()
        # Deinit the microseconds counter
        # micros.deinit()
        # take time different between start and end pulse.
        differ = time.ticks_diff(start, end)
        # Calc the duration of the recieved pulse, divide the result by
        # 2 (round-trip) and divide it by 29 (the speed of sound is
        # 340 m/s and that is 29 us/cm).
        dist_in_cm = (differ / 2) / 29
        return dist_in_cm
orsisam
Post by orsisam » Tue Sep 27, 2016 1:30 am
mcauser wrote:@orsisam paste your git repo when it's ready and I'll help you test it on some of my D1 minis.
I haven't post to Github for the code, but I share the code here.
orsisam
Post by orsisam » Tue Sep 27, 2016 1:44 am
mcauser wrote:The D1 mini has a 5V line, but uses 3V3 logic, so you'll need to use a voltage divider for the Echo pin.
Here's an example of how to do it with a Raspberry Pi
It seems ernitron is right about the current draw being the limiting factor. HC-SR04 has a working current of 15mA but the ESP8266 maximum source/sink current is 12mA per pin.
I see, but I haven't work with this modification. I'll try then.. ;)
ernitron
Post by ernitron » Tue Sep 27, 2016 11:21 am
I spot some problems in the double loop:
If you miss (for some reason) the echo transition you could loop forever in the start and/or never entering in the end loop.
Besides I think that the start counter should be outside the loop otherwise the start will be so close to the end to be useless.
I would write:
    pass
Or the more simplified version of my previous excerpt.
Post by pythoncoder » Tue Sep 27, 2016 12:53 pm
The data sheet http://www.micropik.com/PDF/HCSR04.pdf indicates that you should time from the 10us trigger to the start of the echo pulse. If I understand the Chinglish, that is. So I'd have thought this would work:
    self.trigger.high()
    time.sleep_us(10)
    self.trigger.low()
        pass
This would still hang if no response were received. This could be fixed with a timeout in the loop, which effectively sets the maximum range:
    self.trigger.high()
    time.sleep_us(10)
    self.trigger.low()
        if time.ticks_diff(start, time.ticks_us()) > THRESHOLD:
            break
ernitron
Post by ernitron » Tue Sep 27, 2016 7:29 pm
Right @pythoncoder. If you look at my previous snippet is almost what you propose with a counter instead of a Threshold. Threshold usually is set to 38000 (38 millisec).
I am pretty sure the solution (you propose) to power with a steady source WeMos and HC-SR04 will work. I will test it on a breadbord and then solder a prototype very soon. Thanks.
greentree
Post by greentree » Sun Nov 13, 2016 6:47 pm
Hi! I'm very interested in the potential of using inexpensive acoustic sensors for tide and wave measurements. Thanks for posting your work in progress. Are there any updates on your results and advice?
Lysenko
Post by Lysenko » Sun Nov 13, 2016 6:56 pm
greentree wrote:Hi! I'm very interested in the potential of using inexpensive acoustic sensors for tide and wave measurements. Thanks for posting your work in progress. Are there any updates on your results and advice?
I had more success with these:
http://www.sharpsma.com/webfm_send/1489
... in high humidity environments.
Post by deshipu » Sun Nov 13, 2016 8:34 pm
@Lysenko unfortunately those are analog sensors, and *require* 5V power, so it's non-trivial to connect them to an ESP8266.
I found a similar sensor that uses I2C for communication instead, and wrote a library for it: https://bitbucket.org/thesheep/micropython-gp2y0e03/src
greentree
Post by greentree » Mon Nov 14, 2016 12:30 am
Thanks for these suggestions! I have an analog IR distance sensor -- I can work out the the power issues temporarily while I wait for one of the I2C sensors. I'll give it a try.
I'm still interested in the acoustic sensor, if it is workable. Using sound as a sensing mechanism has some intrinsic value in this application (in a teaching setting, where sound is a topic to be covered). Also, they're cheap enough to hand one out to every student!
