Page 1 of 3
Setting RTC From Internet?
Posted: Mon Sep 26, 2016 11:30 pm
by weldeng
Does anyone have Miicropython Code they could share on how to set the real time clock of the ESP8266 from the internet?
Re: Setting RTC From Internet?
Posted: Tue Sep 27, 2016 6:53 am
See
https://github.com/micropython/micropyt ... ntptime.py. The module ntptime is available by default so you only need to issue
to use it.
Posted: Tue Sep 27, 2016 9:59 pm
by weldeng
Not sure how to use this!
In a August 16th post deshipu gave an easy explaination on how to manually set the RTC (below)
>>>import machine
>>>rtc=machine.RTC()
>>>rtc.datetime((2014, 5, 1, 0, 4, 13, 0, 0))
>>>rtc.datetime()
I am running on battery power and entering deep sleep mode periodically. ESP8266 resets time on waking. I would like to replace the 2nd line of Code above with a call out to the internet to get the time after waking from deepsleep. I am not sure how to use ntptime as you suggest to accomplish this. Any additional assistance is greatly appreciated.
Posted: Wed Sep 28, 2016 4:18 am
by Roberthh
That's what I am using to set the time after boot:
from ntptime import settime
settime()
Posted: Wed Sep 28, 2016 9:50 pm
by weldeng
Roberthh wrote:That's what I am using to set the time after boot:
settime()
>>> settime()
got this error
File "ntptime.py", line 30, in settime
File "ntptime.py", line 22, in time
OSError: [Errno 110] ETIMEDOUT
Repowered and tried it again and the second time it worked
>>> settime()
(2016, 9, 28, 21, 43, 27, 2, 272)
Not sure what wrong the first time but I am going to have to figure out some error handling to account for this happening.
Thanks for the help!!
Posted: Thu Sep 29, 2016 5:25 am
by Roberthh
settime) requires a connection to an NTP server. In my set-up, it sometimes takes a while until the ESP8266 connect to my access point. The do_connect() function from the example waits until this connection is established or runs into a timeout, with exactly the errors you report. This is the exmaple function:
def do_connect():
import network, time
if not sta_if.isconnected():
sta_if.active(True)
sta_if.connect('ap-name', 'password')
pass
print('network config:', sta_if.ifconfig())
You may get the timeout there. After I replaced the wait loop by:
print(".", end="")
time.sleep(1)
the connections is always established.
Posted: Tue Nov 01, 2016 2:05 am
by NTL2009
So I entered the code above to connect to my local wi-fi network (which I've used OK before), and then executed the commands:
>>> settime()
(2016, 11, 1, 1, 55, 21, 1, 306)
and the data returned was the current GMT time, so it obviously got out to the pool.ntp.org servers and updated my ESP board. So far so good!
Format looks to be (year, month, day, hours, minutes, seconds, weekday, yearday), with Monday = 0 weekday.
But now I'm stuck. How do I pull that data out to use in my program? I'm new at this, so if you can , please give specifics, like which command and what variables it can be read into. I don't know if the settime() can be read into a variable (I haven't figured out how - it seems to be only for updating the clock, and it reports back the status?). What, and how, do I read the current time to use n my program? I've searched, but I'm lost.
Posted: Tue Nov 01, 2016 2:23 am
by chrisgp
Check out
utime and
machine.RTC. Their functions will give the appropriate time once you've made the NTP call to sync up.
For example utime.localtime() will return back a tuple with the various fields available.
Posted: Tue Nov 01, 2016 2:36 am
by NTL2009
chrisgp wrote:Check out
utime and
Thanks, I came across each of those in my previous searches, but since I'm so new to this, I don't know how to actually implement those instructions in a program. I haven't found actual code examples. So far, I've been able to figure things like this out, but I'm just stuck on the actual implementation of any of those commands. Probably a mental block on my part, but I'm stuck. Code examples would really help me get over this bump.
UPDATE: OK, I think I'm getting there...
>>> import utime
>>> utime.localtime()
(2016, 11, 1, 2, 41, 43, 1, 306)
>>> ts = utime.localtime()
>>> ts
(2016, 11, 1, 2, 42, 44, 1, 306)
# (YYYY, MM, DD, HH, MM, SS, Day of week [Monday=0], Day of year)
# ts[0] returns 2016; ts[7] returns 306
# ts[0:7] returns(2016, 11, 1, 2, 42, 44, 1)
Posted: Tue Nov 01, 2016 4:11 am
by chrisgp
Here's a simple example. It prints the day of the week and the month in textual format. After that it goes into a loop where it prints a message once each Tuesday by watching a triggered flag.
(year, month, mday, hour, minute, second, weekday, yearday) = utime.localtime()
days= {0:"Monday", 1:"Tuesday", 2:"Wednesday", 3:"Thursday", 4:"Friday", 5:"Saturday", 6:"Sunday"}
months = {1:"January", 2:"February", 3:"March", 4:"April", 5:"May", 6:"June", 7:"July", 8:"August", 9:"September", 10:"October", 11:"November", 12:"December"}
print("Today is {}".format(days[weekday]))
print("The month is {}".format(months[month]))
triggered = False
time.sleep(1)
if weekday != 1:
triggered = False
elif not triggered:
triggered = True
print("I execute once each Tuesday.")
paste mode; Ctrl-C to cancel, Ctrl-D to finish
=== (year, month, mday, hour, minute, second, weekday, yearday) = utime.localtime()
=== days= {0:"Monday", 1:"Tuesday", 2:"Wednesday", 3:"Thursday", 4:"Friday", 5:"Saturday", 6:"Sunday"}
=== months = {1:"January", 2:"February", 3:"March", 4:"April", 5:"May", 6:"June", 7:"July", 8:"August", 9:"September", 10:"October", 11:"November", 12:"December"}
=== print("Today is {}".format(days[weekday]))
=== print("The month is {}".format(months[month]))
=== triggered = False
=== while True:
=== time.sleep(1)
=== if weekday != 1:
=== elif not triggered:
=== triggered = True
=== print("I execute once each Tuesday.")
Today is Tuesday
The month is November
