Telnet Server
Re: Telnet Server
Post by Roberthh » Mon Oct 10, 2016 6:50 pm
As far as I could tell, importing & starting the telnet server reduced the free memory by 1616 bytes, and it's not frozen bytecode. As frozen bytecode, it's 640 bytes.
Re: Telnet Server
Post by pythoncoder » Tue Oct 11, 2016 9:22 am
Oops, sorry. Brain fade yesterday. Some figures based on frozen bytecode on the reference board.
Accessing via USB:
After import, usage 480 bytes
After starting server 608 bytes.
I then edited main.py to run it at boot, power cycled the board and accessed it over WiFi via Telnet. Usage (relative to the free RAM reported in the first test) was 1408 bytes.
warren
Re: Telnet Server
Post by warren » Wed Dec 14, 2016 8:21 am
This is very useful. but I have a strange problem when typing.
I am connecting to the ESP8266 module over my LAN. I am using Putty for telnet. It connects immediately and in the Putty window I see the same flow of stuff on REPL as I am seeing through the serial connection.
When I type I cannot see what I am typing!
But what I type is definitely received and acted upon by REPL...its just that I cant see it when i am typing. And this applies to BOTGH the Putty console and on the serial view - when I am typing, nothing shows.
Also, CTRL-C does not work
Any hints?
Re: Telnet Server
Post by Roberthh » Wed Dec 14, 2016 7:57 pm
That seems to be a putty configuration problem. It seems to be in line edit mode. In the terminal setting of putty's configuration, set local line editing to force off. Then it works.
warren
Re: Telnet Server
Post by warren » Thu Dec 15, 2016 6:02 am
Roberthh wrote:That seems to be a putty configuration problem. It seems to be in line edit mode. In the terminal setting of putty's configuration, set local line editing to force off. Then it works.
Doh!
Thanks so much - works perfectly.
jpj
Re: Telnet Server
Post by jpj » Thu Dec 15, 2016 1:14 pm
Very useful! Thank you for writing and sharing it.
ttmetro
Re: Telnet Server
Post by ttmetro » Tue Dec 05, 2017 3:39 am
Will this telnet server (or any other telnet) work with the standard (official) ESP32 microphython port?
[ I've been using the Pycom and the Loboris ports for this feature; both are (more or less) subtly different from standard microphython. ]
Bernhard
Bernhard Boser
