Telnet Server
Re: Telnet Server
Post by Roberthh » Mon Oct 10, 2016 6:50 pm
As far as I could tell, importing & starting the telnet server reduced the free memory by 1616 bytes, and it's not frozen bytecode. As frozen bytecode, it's 640 bytes.
Re: Telnet Server
Post by pythoncoder » Tue Oct 11, 2016 9:22 am
Oops, sorry. Brain fade yesterday. Some figures based on frozen bytecode on the reference board.
Accessing via USB:
After import, usage 480 bytes
After starting server 608 bytes.
I then edited main.py to run it at boot, power cycled the board and accessed it over WiFi via Telnet. Usage (relative to the free RAM reported in the first test) was 1408 bytes.
warren
Re: Telnet Server
Post by warren » Wed Dec 14, 2016 8:21 am
This is very useful. but I have a strange problem when typing.
I am connecting to the ESP8266 module over my LAN. I am using Putty for telnet. It connects immediately and in the Putty window I see the same flow of stuff on REPL as I am seeing through the serial connection.
When I type I cannot see what I am typing!
But what I type is definitely received and acted upon by REPL...its just that I cant see it when i am typing. And this applies to BOTGH the Putty console and on the serial view - when I am typing, nothing shows.
Also, CTRL-C does not work
Any hints?
Re: Telnet Server
Post by Roberthh » Wed Dec 14, 2016 7:57 pm
That seems to be a putty configuration problem. It seems to be in line edit mode. In the terminal setting of putty's configuration, set local line editing to force off. Then it works.
warren
Re: Telnet Server
Post by warren » Thu Dec 15, 2016 6:02 am
Roberthh wrote:That seems to be a putty configuration problem. It seems to be in line edit mode. In the terminal setting of putty's configuration, set local line editing to force off. Then it works.
Doh!
Thanks so much - works perfectly.
jpj
Re: Telnet Server
Post by jpj » Thu Dec 15, 2016 1:14 pm
Very useful! Thank you for writing and sharing it.
ttmetro
Re: Telnet Server
Post by ttmetro » Tue Dec 05, 2017 3:39 am
Will this telnet server (or any other telnet) work with the standard (official) ESP32 microphython port?
[ I've been using the Pycom and the Loboris ports for this feature; both are (more or less) subtly different from standard microphython. ]
Bernhard
Bernhard Boser
Jongy
Re: Telnet Server
Post by Jongy » Thu Feb 21, 2019 8:00 pm
Bernhard
I've tried this now on an ESP32 and it doesn't work, getting this error:
  File "utelnetserver.py", line 81, in accept_telnet_connect
OSError: stream operation not supported
which is quite expected by looking at the code, I admit.
Anyway I've come to a conclusion that I want telnet on my ESP32 because it would work much more smooth compared with the webrepl, so I'll keep you updated once I get this working :)
Re: Telnet Server
Post by Roberthh » Thu Feb 21, 2019 8:30 pm
The change is simple. According to the hint here viewtopic.php?f=8&t=5868&p=33586&hilit=dupterm#p33586 add
from uio import IOBase
to the import section and change
class Telnetserver()
into
class Telnetserver(IOBase)
as shown below in the code snippet:
import socket
import uos
import errno
last_client_socket = None
server_socket = None
# Provide necessary functions for dupterm and replace telnet control characters that come in.
class TelnetWrapper(IOBase):
    def __init__(self, socket):
        self.socket = socket
        self.discard_count = 0
Jongy
Re: Telnet Server
Post by Jongy » Sat Feb 23, 2019 10:10 pm
into
import socket
import uos
import errno
Thanks! That really fixed it.
I was puzzled by this as I didn't realize which magic connects my object with its `write`, `readinto` methods to what `mp_uos_dupterm` accepts. `iobase_read` and `iobase_write` were what I missed...
The `uos.dupterm` should definitely be updated so people won't have to look in the code next time.. :P
