Socket with IP filtering
joehunt588
Post by joehunt588 » Wed Oct 05, 2016 1:47 pm
Hi Guy,
i wanna share my code using socket,by set esp8266 as access point this code can filter banned ip address,this code can treat as AT command protocol .
Please give comment ,
server.py:
#for ESP8266
import socket
sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
sock.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
server_address = ("", 11000)
print("Starting up on =",server_address)
sock.bind(server_address)
sock.listen(1)
    print ('waiting for a connection')
    connection, client_address = sock.accept()
    print (client_address[0])
    # can use to filter ip address
    if client_address[0] == '192.168.0.88':
        print ("Client ip is banned")
            print ('connection from', client_address)
                data = connection.recv(1024)
                print('received ' ,data)
                if data:
                    print ('sending data back to the client')
                    datainput=input('>>')
                    datainput = bytes(datainput,"utf-8")
                    print (datainput)
                    connection.sendall(datainput)
                    print ('no more data from', client_address)
                    break
        finally:
            connection.close()
client.py:
# for pc
import socket
# Create a TCP/IP socket
# Connect the socket to the port where the server is listening
server_address = ('192.168.4.1', 11000)
print ('connecting to %d port %d', server_address)
sock.connect(server_address)
    message ='This is the message.  It will be repeated '
    sock.sendall(message)
    (data,addr) = sock.recvfrom(1024)
    print(data)
finally:
    print ('closing socket')
    sock.close()
PS* i will share apk for smart phone also after my exam finish ,
guy wish me luck for my exam. ;)
