That's actually not the case. The machine module, on any system/port, deals directly with hardware, even if via a very thin shim, as in the case of "virtual timers" (there're no wonders what are they - they are a list of data structures, which a hardware interrupt handler goes thru and calls right from itself). Trying to do high-level networking in a hardware timer interrupt is akin to jumping up, and at the highest point to have a breakfast.pythoncoder wrote:It seems that the capabilities of callbacks from ESP8266 virtual timers are somewhat undefined.
Docs http://docs.micropython.org/en/latest/e ... chine.html http://docs.micropython.org/en/latest/e ... Timer.html now make explicit the requirement above (of all machine module callbacks to be considered to be run in IRQ context).
If you need to pass time, time.sleep_ms() is your friend. If you need to do more complex scheduling, uasyncio.core is now in good shape for ESP8266 (or any other system). Networking scheduling is done via main uasyncio module and so far experimental on ESP8266.
