Hello everyone,
As a beginner in the mcu world and after getting my feet wet with my first i2c device driver (a rtc mp3231) I got to work with an ADXL345 accelerometer.
I saw here and there some post about it, but my problem is not specific to the device itself (or the ESP8266 for that matter).
I'm able to extract legit values as long as the acceleration is positive, but I cannot make it with a negative one.
In the datasheet is made clear that the output data is two's complement... and here is my problem. How can correctly convert a negative value to decimal?
I printed the value of an axis and while transitioning from a positive value to a negative this is what I got:
Positive: 0b11
Negative: 0b1111111111111110
I (think to) understand theoretically how this work, but how do I convert it to a decimal value? I thought that the complement (~) was the way to go, but seems that it's not the case or, more probably, I don't know how to use it.
Thanks!
Working on a simple ADXL345 driver (i.e. two's complement)
Re: Working on a simple ADXL345 driver (i.e. two's complement)
# from stackoverflow J.F. Sebastian
def _twos_comp(val, bits=8):
"""compute the 2's complement of int val with bits"""
if (val & (1 << (bits - 1))) != 0: # if sign bit is set
val = val - (1 << bits) # compute negative value
return val # return positive value as is
Just convert the number to decimal and subtract 2 to the power bit_count. e.g:
int('1111111111111110',2) - (2**16) = -3
There might be some function or other in the stdlib for this, but it's easier to remember the basic math than library functions for one liners.
Thanks to both!!
