What makes WiFi config persistent?
cpr
Post by cpr » Mon Oct 31, 2016 8:12 pm
:?: If I follow the docs at http://docs.micropython.org/en/latest/e ... f-the-wifi and use
def do_connect():
    if not sta_if.isconnected():
        sta_if.active(True)
        sta_if.connect('<essid>', '<password>')
            pass
    print('network config:', sta_if.ifconfig())
in my main.py
to connect to my WiFi,
this is what I get at the REPL by connectoing with screen /dev/ttyUSB0 115200:
scandone
no <essid> found, reconnect after 1s
reconnect
scandone
reconnect
I am (only) curious as what this makes the config persistent?
Is that some Espressif stuff?
Would I need to
sta_if.active(False)
in some "shutdown" code to dsable this?
markxr
Re: What makes WiFi config persistent?
Post by markxr » Mon Oct 31, 2016 9:13 pm
The API provided by the espressif firmware does this automatically when you call the function to set the config.
There is a second function which does not save the config, there is a big discussion in this pull request:
https://github.com/micropython/micropython/pull/2510
On how / whether to use it.
bitninja
Post by bitninja » Mon Oct 31, 2016 11:37 pm
I believe is actually implements it by writing the credentials to EEPROM. I seem to remember Arduino code that could manage it by reading/writing to the EEPROM.
Setting the STA interface to not be active will disable the constant trying to connect. All you have to do is re-enable it though (even after a reboot) and it will begin trying to connect again with the info stored in the EEPROM.
Anyway, it all seems to happen automatically... which ends up being convenient... at least for me!
cemox
Post by cemox » Thu Apr 30, 2020 8:25 am
Yesterday, I compiled the latest version of micropython for ESP8266 and I started seeing this annoying output in repl repeatedly:
connected with Cisti, channel 1
dhcp client start...
ip:192.168.1.4,mask:255.255.255.0,gw:192.168.1.1
state: 5 -> 2 (22c0)
rm 0
reconnect
state: 2 -> 0 (0)
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 7
cnt
I have to enter "ctrl + c" to access the repl promt. Pretty annoying. It was not the case with 1.12 version of binary. Any ideas about how to get rid of it or suppress it?
jomas
Post by jomas » Thu Apr 30, 2020 1:27 pm
rm 0
reconnect
state: 2 -> 0 (0)
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 7
cnt
See my post "jomas » Tue Apr 28, 2020 11:07 pm":
viewtopic.php?f=16&t=8234
bitninja
Post by bitninja » Thu Apr 30, 2020 10:12 pm
If you edit your boot.py you can un-comment the
import esp
esp.osdebug(None)
lines and that will remove most of the messages. I still get one message when I connect but otherwise it stays quiet.
cemox
Post by cemox » Fri May 01, 2020 3:37 pm
Thank you, it works.
