I'm new to MicroPython and a bit new to Python too. I'm trying to send data using sockets to an ESP8266. I want the ESP8266 to be the server and my pc to be the client but I get an error when trying to receive data and I can't find any helpfull documentation to help me in this case.
This is my code:
[code]
import socket
p = machine.Pin(2, machine.Pin.OUT)
p.low()
ap_if = network.WLAN(network.AP_IF)
if (ap_if.active()):
ap_if.active(False)
sta_if.active(True)
sta_if.connect('MY_AP','PASSWORD')
while not sta_if.isconnected():
pass
print('network config:', sta_if.ifconfig())
ips = sta_if.ifconfig()
def server_init():
s = socket.socket()
s.bind( ('', 3266) )
s.listen(1)
c, a = s.accept()
time.sleep(5)
data= s.recv()
print(dato)
server_init()
[/code]
It connects to the ap perfectly and when I try to connect using nc 192.168.1.133 3266, it accepts and then it fails. in the data = s.recv() line.
I try to reproduce the error using repl and when I get to the s.recv() line I get:
OSError: 0
It just fails.
Can anyone give me any hints?
Thank you.
Problem using Sockets
Re: Problem using Sockets
Are you sure that these two lines are in your code?
The second line should fire an error, unless your codes says:
data= s.recv()
print(dato)
print (data)
Hi Roberthh
Yes, they are.
It even throws an error when I try it via repl directly.
Yes, they are.
So that's how my test code looks like:
Edit: Simplified to you base code
import socket
def server_init():
s = socket.socket()
s.bind( ("", 3266) )
s.listen(1)
c, a = s.accept()
time.sleep(1)
data= c.recv(1)
print(data)
if not data:
break
server_init()
Thank you very much. My problem was that I was using the socket (s) with the recv method instead of the client (c).
Now it works but I think documentation is not right then:
https://docs.micropython.org/en/latest/ ... k_tcp.html
http://docs.micropython.org/en/latest/w ... ocket.send
Right?
Or am I missing something?
Right?
Hi @Twistx77. The example you point at shows a client, which opens a connection to a server, while you code creates a server which accepts connections opened by a client.
You can only call send and recv against a connected socket and a listening socket is not connected to anything.Twistx77 wrote:Hi,
Right?
If a server listens on 192.168.1.1:5000 and a client connects to that address/port combination the server will create a new socket on 192.168.1.1:<random_port_number> and connect the client to it. This is transparent to the client which sees it as a connection on port 5000 but from a server perspective the port (and therefore socket) the client connected to is not the one that actually gets connected and carries the data.
Thanks to both for the clarification.
I understand now what my problem is.
I couldn't find an example of my case so I hope this helps someone else
Once again thanks again to both.
