Pin interrupts triggering errantly?
BobRyan
Post by BobRyan » Sun Nov 06, 2016 9:47 pm
I've got an application which takes input from a SPDT switch connected to pins 0 and 2. I'm seeing both interrupts triggered (almost) every time one should. I've checked the inputs on my scope and with a logic analyzer and while there's a tiny bit of bounce there's no action on the other pin.
I assume this must be a software problem so I tried a few different releases of micropython but I have the same behavior with each.
Perhaps someone could shed some light on this or perhaps test it in their environment?
I've added the print() and disable/enable_irq calls while debugging this and they seem to make no difference.
Thanks -Bob
apologies, code formatting doesn't seem to be working. code is indented as expected.
from time import sleep_us
from machine import disable_irq, enable_irq
def up_swcb(p):
	irq_state = disable_irq()
	global direction, trigger
	trigger = 0
	direction = 1
	print('up switch callback')
	enable_irq(irq_state)
def down_swcb(p):
	trigger = 0
	direction = -1
	print('down switch callback')
up_sw = Pin(2, Pin.IN, Pin.PULL_UP)
down_sw = Pin(0, Pin.IN, Pin.PULL_UP)
up_sw.irq(trigger=Pin.IRQ_FALLING, handler=up_swcb)
down_sw.irq(trigger=Pin.IRQ_FALLING, handler=down_swcb)
	sleep_us(1000)
and my results with the following switch sequence: up, up, down
MicroPython v1.8.3-dirty on 2016-11-06; ESP module with ESP8266
paste mode; Ctrl-C to cancel, Ctrl-D to finish
=== from time import sleep_us
=== from machine import Pin
=== from machine import disable_irq, enable_irq
=== def up_swcb(p):
===     irq_state = disable_irq()
===     global direction, trigger
===     trigger = 0
===     direction = 1
===     print('up switch callback')
===     enable_irq(irq_state)
=== def down_swcb(p):
===     trigger = 0
===     direction = -1
===     print('down switch callback')
=== up_sw = Pin(2, Pin.IN, Pin.PULL_UP)
=== down_sw = Pin(0, Pin.IN, Pin.PULL_UP)
=== up_sw.irq(trigger=Pin.IRQ_FALLING, handler=up_swcb)
=== down_sw.irq(trigger=Pin.IRQ_FALLING, handler=down_swcb)
=== while True:
===     sleep_us(1000)
<IRQ>
<IRQ>
up switch callback
up switch callback
up switch callback
up switch callback
up switch callback
up switch callback
up switch callback
MicroPython v1.8.4 on 2016-11-06; ESP module with ESP8266
=== def up_swcb(p):
===     trigger = 0
===     direction = 1
===     trigger = 0
===     direction = -1
=== while True:
===     sleep_us(1000)
<IRQ>
<IRQ>
up switch callback
up switch callback
up switch callback
up switch callback
up switch callback
up switch callback
up switch callback
up switch callback
MicroPython v1.8.5 on 2016-11-06; ESP module with ESP8266
=== def up_swcb(p):
===     trigger = 0
===     direction = 1
===     trigger = 0
===     direction = -1
=== while True:
===     sleep_us(1000)
<IRQ>
<IRQ>
up switch callback
up switch callback
up switch callback
up switch callback
up switch callback
up switch callback
up switch callback
up switch callback
up switch callback
with sdk 2.0
MicroPython v1.8.5-122-g8f068e8 on 2016-11-06; ESP module with ESP8266
=== def up_swcb(p):
===     trigger = 0
===     direction = 1
===     trigger = 0
===     direction = -1
=== while True:
===     sleep_us(1000)
<IRQ>
<IRQ>
up switch callback
up switch callback
up switch callback
up switch callback
up switch callback
up switch callback
tknp
Re: Pin interrupts triggering errantly?
Post by tknp » Sun Feb 19, 2017 6:29 am
Just echoing that I am seeing the same behavior as you are. It looks like the interrupts are being triggered not just when the specific interrupt state is listed but by any change.
Post by dhylands » Sun Feb 19, 2017 6:34 pm
I highly recommend that anybody dealing with real physical switches read this:
http://www.ganssle.com/debouncing.htm
tknp
Post by tknp » Sun Feb 19, 2017 11:10 pm
That was an informative read. Thanks for that. Looking forward to implementing some debouncing strategies now.
