UMQTT - Can it support multiple publish statements?
haybarry
Post by haybarry » Mon Nov 07, 2016 10:37 am
Hi clever people,
I have a ESP-01 (with 32m serial rom) connected to a DHT-11. I am trying to publish to separate streams for Temperature and Humidity.
I can publish to one stream, and have a gauge on a RPi with Node RED to display my data. But if I add an extra publish statement to a second stream, my code crashes with
WebREPL daemon started on ws://0.0.0.0:8266
Started webrepl in normal mode
File "main.py", line 4, in <module>
MemoryError:
MicroPython v1.8.5-10-g0e69e6b on 2016-10-17; ESP module with ESP8266.
Using Micropython 1.8.5, and UMQTT.Simple
Last bit of code is
if cycle > 5:
cycle = 0
print('George')
c.publish(b'Ghouse/Temp', str(Temp_Now))
c.publish(b'Ghouse/Humid', str(Humid_Now))
get_temp = False
I can comment out either publish statement and the code will work, but not both.
Have I run into a limitation, or just doing something dumb.
Thanks for your collective wisdom
Cheers
Barry
Online
jonaslorander
Re: UMQTT - Can it support multiple publish statements?
Post by jonaslorander » Thu Nov 17, 2016 8:43 pm
I'm sending three values using three different publishes after each other.
And I had the same problem, so I tried adding a short sleep before sending the next publish:
mqttc.publish(TOPIC_DS1_T, "%3.2f" % ds1_t)
time.sleep_ms(20)
mqttc.publish(TOPIC_DHT1_T, "%3.2f" % dht1_t)
time.sleep_ms(20)
mqttc.publish(TOPIC_DHT1_H, "%3.2f" % dht1_h)
And this works!
Regards,
Jonas
