Can't flash 1.8.5 (or 1.8.4) on NodeMCU
Hello Friends,
I am having a lot of trouble flashing micropython 1.8.5 (or 1.8.4) firmware to my NodeMCUs. Some months ago this worked fine with the same boards. Now, the flashing happens without any error but upon reset the LED blinks like mad and garbage is spewed to the screen non-stop. The same boards are able to run NodeMCU Lua firmware without problem.
I am erasing the flash before flashing and I tried many different incantations of the esptool.py command. I am trying this with multiple boards, all the same model from the same maker. I have been trying this to flash it:
esptool.py --port COM3 --baud 115200 write_flash --flash_size=8m -fm dio 0 esp8266-20161017-v1.8.5.bin
The same process work with the Lua based firmware if I also pass the option to flash esp_init_data_default.bin. These boards used to work fine with 1.8.4, so I tried flashing them with that version again and it didn't work, same bug.
Is anyone experiencing the same problem? Anyone has some advise?
Thanks for all the help
Re: Can't flash 1.8.5 (or 1.8.4) on NodeMCU
Do you get the same error if you try --flash_size=32m?
Which version of esptool?
I noticed that erasing the flash doesn't do much when the board gets stuck like that. What worked for me is flashing a different firmware (nodemcu or espruino), and then flashing MicroPython on top of that. I have no idea why that happens -- a flash dump after erase_flash returns all 0xff, so seems it worked fine...
Hi, I tried both fs 32m and 8m, same results. I am using esptool 1.1 on windows (This used to work). I can flash the nodemcu lua one without problem tough.mcauser wrote:Do you get the same error if you try --flash_size=32m?
thanks for the reply.
Tried that as well, more than once. Will try again because I think I was flashing the lua firmware then erasing flash then flashing micropython. Will try without erasing the flash.deshipu wrote:I noticed that erasing the flash doesn't do much when the board gets stuck like that. What worked for me is flashing a different firmware (nodemcu or espruino), and then flashing MicroPython on top of that. I have no idea why that happens -- a flash dump after erase_flash returns all 0xff, so seems it worked fine...
Thanks for the tip.
Just tried this. Didn't worksoapdog wrote:Tried that as well, more than once. Will try again because I think I was flashing the lua firmware then erasing flash then flashing micropython. Will try without erasing the flash.deshipu wrote:I noticed that erasing the flash doesn't do much when the board gets stuck like that. What worked for me is flashing a different firmware (nodemcu or espruino), and then flashing MicroPython on top of that. I have no idea why that happens -- a flash dump after erase_flash returns all 0xff, so seems it worked fine...
Thanks for the tip.
Damn, I am about to publish a course on micropython and nodemcu and all my boards stopped working
What is the real flash size of your flash ROM? The discussion does mention settings from 8mb to 32mb for esptool.
If your modules have only 512KB of flash this might be of interest to you:
A few weeks ago the MicroPython builds did exceed the initially set 512KB flash barrier. pfalcon did introduce a new build target '512k' for the ESP8266 port to compensate the situation.
You can look at this commit for details about this change. But most likely you will not like what you can read there for your course (FatFS and file related functionalities got removed completetly).
esptool gives me the following output:kfricke wrote:What is the real flash size of your flash ROM? The discussion does mention settings from 8mb to 32mb for esptool.
C:\Users\soapdog\Downloads
λ esptool.py --port COM3 flash_id
esptool.py v1.1
Connecting...
Manufacturer: e0
Device: 4016
Looks to me a bad flash or a bad image: in that case the unit continue rebooting flashing the LED.
It happened to me something similar NodeMCU was working fine and Micropython was flashing. Connecting with picocom presented garbled characters on screen continuously. As @kfricke noted, my problem was the wrong memory settings (WeMos D1 mini requires 32m and -fs=detect did not worked).
I would check all the memory sizes. Note that an update to esp-open-sdk (compiler along with esptool.py) to latest version is mandatory for 1.8.5.
xgcc --version
xtensa-lx106-elf-gcc (crosstool-NG crosstool-ng-1.22.0-55-gecfc19a) 4.8.5
That does seem to be the case. How about trying a newer version of esptool? The current release is 1.2.1.
