Avoid flash wearing by altering behavior originally introduced by Espressif (the inventor of the ESP8266)
Would you like to make good-intended, but backward-incompatible changes to WiFi setup?
Poll ended at Sun Jan 08, 2017 7:55 am
Yes, I think this change is good, even though it's backward-incompatible and will confuse some users. We'll get thru it.
36
100%
No, I don't think this change is sound technically or that making backward-incompatible changes of such scale is good.
0
No votes
Total votes: 36
Re: Avoid flash wearing by altering behavior originally introduced by Espressif (the inventor of the ESP8266)
Post by dhylands » Thu Nov 10, 2016 5:33 pm
Lysenko wrote:
dhylands wrote:So the last time a password was written was in Aug, over 3 months ago, even though my laptop has been rebooted several times. The first file "Blue-Heron" is the SSID I normally connect to, and it hasn't changed since I installed 16.04.
OK, but what do you get if you use -lu instead?
That will show the last time the file was "read", which doesn't relate to this discussion.
Frida
Post by Frida » Thu Nov 10, 2016 6:23 pm
An extract from Espruino with Javascript, where we have wifi.save()
var wifi = require("Wifi");
wifi.connect("my-ssid", {password:"my-pwd"}, function(ap){ console.log("connected:", ap); });
wifi.stopAP();
You may want to add wifi.setDHCPHostname("espruino"). Once you're happy with your connection, you can use wifi.save() to persist it, so you don't have to reconnect each time you reset your ESP8266.
Yes Frida is my watchdog!
marfis
Post by marfis » Thu Nov 10, 2016 7:30 pm
+1
should esp.save_config be renamed to wifi.save_config?
esp.save_config sounds a bit general to me.
Other than that that proposal sounds good! Thanks for your effort.
kfricke
Post by kfricke » Thu Nov 10, 2016 8:23 pm
I did place it inside the esp module, because it is only specific to this platform.
mcauser
Post by mcauser » Thu Nov 10, 2016 9:32 pm
My $0.02: If a seeming small change can reduce e-waste and shipping pollution, that's a win for the environment.
markxr
Post by markxr » Thu Nov 10, 2016 10:55 pm
Oh dear. (I posted the bug that started this. Sorry.)
I really, really, didn't plan on starting this "Holy War".
Please take a chill pill (or two).
For my part, I'd be happy with any reasonable solution which allows connecting / disconnecting without wearing the flash. If it's backwards-compatible, great, if not, great as well.
Mark
woodat
Post by woodat » Thu Nov 10, 2016 10:59 pm
Just finished reading through all pages of this post and am left with a question: given there's no technical reason against it, was there anything wrong with the compromise solution proposed? If I read all this correctly, the suggestion was implementing a save_config() with an optional boolean to allow the original behaviour (pfalcon's desire) but at the same time provide the optional non-write functionality that 100% of the active readers on this forum (thus far) also seem to desire?
How does that break anyone's experience or backward compatibility?
jknuteson
Post by jknuteson » Fri Nov 11, 2016 1:14 am
I think it essential to address this issue because many if not most applications will use deepsleep to reduce power consumption, and if its use ultimately causes hardware failure in a relatively short lifespan, then the ESP8266-micropython combination is not a valid choice of platform.
Post by Roberthh » Fri Nov 11, 2016 7:38 am
Hello Woodat. Without knowing the details, I assume that even that implementation requires a change in the esp-sdk toolchain, if possible at all, which then would have to be maintained. And that's what Paul want to avoid, I guess.
kfricke
Post by kfricke » Fri Nov 11, 2016 8:10 am
Nö Robert, the suggested changes in my pull request do only use official API calls. It changes only the two (or maybe three) year old default behaviour of the ESP8266. Those additional API methods have been introduced with a early version 1.0 and are still present in the 2.0 SDK. What pfalcon wants to avoid is the additional support he feats from that change.
