Problem server does not load the total file htm.
alien
Post by alien » Sat Nov 19, 2016 5:11 pm
I use this example in Esp8266 micropython https://github.com/RinusW/WiPy/tree/master/AiCWebserver
The problem is that the server does not display the total file htm.
Screenshot:
https://dl.dropboxusercontent.com/u/170 ... ie_001.png
https://dl.dropboxusercontent.com/u/170 ... ie_002.png
Does not load the total file htm.
What am I doing wrong ?
Re: Problem server does not load the total file htm.
Post by deshipu » Sat Nov 19, 2016 8:14 pm
Try using conn.sendall in place of con.send...
alien
Post by alien » Sat Nov 19, 2016 8:34 pm
Thank you, it works. However, constantly pop up errors in the terminal and the server crashes.Probably the problem is resources esp8266
Post by deshipu » Sun Nov 20, 2016 9:34 am
Yes, you should send the file in smaller pieces, not all at once.
alien
Post by alien » Tue Nov 22, 2016 8:43 pm
Please can someone show an example of how to send html file in several parts. I'm a beginner.
Post by Roberthh » Wed Nov 23, 2016 5:15 pm
For me. the example works. I just changed the send() at sending the web page into sendall(), and replaced the tab's by spaces (the latter was not required). You do not have to split the send, since the data amount in minor.
aicwebtest.zip
(1.28 KiB) Downloaded 241 times
alien
Post by alien » Wed Nov 23, 2016 6:10 pm
Thank you
