Page 2 of 2
Re: [SOLVED/WORKEDAROUND] Having problems with HX711 load cell sensor
Posted: Fri Dec 29, 2017 8:13 am
The problem is with the
myus variable. You are issuing += against this when it has not been assigned an initial value. The following line 8 should fix it.
def read(self):
self.powerUp()
while not self.isready():
pass
print("<waiting finished> dataPin: {}, sckPin: {}".format(self.dataPin.value(), self.pdsckPin.value()))
my = 0
now = utime.ticks_us()
myus = '' # ***** add this line *****
for i in range(24):
self.pdsckPin.value(1)
self.pdsckPin.value(0)
data = self.dataPin.value()
myus += ", " + str(utime.ticks_diff(utime.ticks_us(), now))
mydata += str(data)
my = ( my << 1) | data
print("bitbanged: ", my)
print("us: ", myus)
print("data: ", mydata)
Posted: Sun Dec 31, 2017 8:13 pm
by delarge
thank you for the reply mate!
I've added the line:
def read(self):
self.powerUp()
pass
my = 0
myus = ''
for i in range(24):
mydata += str(data)
print("us: ", myus)
for i in range(3):
utime.sleep_us(2)
self.powerDown()
but sadly the error remains:
>>> HX711()
<waiting finished> dataPin: 0, sckPin: 0
File "<stdin>", line 14, in __init__
File "<stdin>", line 34, in read
NameError: local variable referenced before assignment
I would appreciate any other hint!
Posted: Tue Jan 02, 2018 1:50 pm
I think you have made the same mistake with mydata.
Posted: Tue Jan 09, 2018 12:52 pm
by delarge
Indeed I have. Thank you mate.
Best Regards.
Posted: Wed Aug 29, 2018 10:05 pm
by oliverr
Hey guys, just wanted to say thank you for the information in this thread, helped me get my HX711 load sensor up and running with less hassle! I've put a bit of a class together that should hopefully help any future HX711 users, can find it on my Github:
https://github.com/HowManyOliversAreThe ... mpy-driver
Posted: Thu Aug 30, 2018 5:55 am
by Roberthh
That one looks fine. Adding gain is just a minor additional step. For interest, I also made a driver using SPI. In that case, MOSI is used as the clock signal. The SPI clock signal is not used. The core of the class is below. It was made for a LoPy, so it does not immediately run. The interesting parts are the data structures for clock and the lookup table for fast transformation. The reason for using SPI was, that the ESP32 just like the ESP8266 is not good at fast toggling and reading, eventually not matching the timing requirements of the HX711. Using SPI ensures fast timing.
class HX711:
def __init__(self, dout, pd_sck, spi_clk, gain=128):
self.pSCK = Pin(pd_sck , mode=Pin.OUT)
self.pOUT = Pin(dout, mode=Pin.IN, pull=Pin.PULL_DOWN)
self.spi = SPI(0, mode=SPI.MASTER, baudrate=1000000, polarity=0, phase=0, pins=(spi_clk, pd_sck, dout))
self.pSCK(0)
self.clock_25 = b'\xaa\xaa\xaa\xaa\xaa\xaa\x80'
self.clock_26 = b'\xaa\xaa\xaa\xaa\xaa\xaa\xa0'
self.clock_27 = b'\xaa\xaa\xaa\xaa\xaa\xaa\xa8'
self.clock = self.clock_25
self.lookup = (b'\x00\x01\x00\x00\x02\x03\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
b'\x04\x05\x00\x00\x06\x07\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
b'\x08\x09\x00\x00\x0a\x0b\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
b'\x0c\x0d\x00\x00\x0e\x0f')
self.in_data = bytearray(7)
self.set_gain(gain);
def set_gain(self, gain):
if gain is 128:
elif gain is 64:
self.clock = self.clock_27
elif gain is 32:
self.clock = self.clock_26
self.read()
def read(self):
# wait for the device to get ready
while self.pOUT() != 0:
idle()
# get the data and set channel and gain
self.spi.write_readinto(self.clock, self.in_data)
# pack the data into a single value
result = 0
for _ in range (6):
result = (result << 4) + self.lookup[self.in_data[_] & 0x55]
# return sign corrected result
return result - ((result & 0x800000) << 1)
Posted: Sat Jan 04, 2020 2:42 am
by loadcellengineer
You might want to read this info on
instructables for the Hx711. It has complete specs but you might need an account.
I use the
load cell manufactured in the US by transducer Techniques. They are really helpfull too.
Posted: Sun Mar 15, 2020 5:15 pm
by monkeyjacob17
@Roberthh : How did you calibrate the HX711 with a lopy? How do you define the calibrate parameter?
Thanks,
Posted: Sun Mar 15, 2020 7:15 pm
by Roberthh
I did not calibrate yet. It depends on the actual load cell you are using and your mechanical set-up. Then you would take the zero-load value and the value for a known load and use that for calibration with a simple linear equation approach ((actual_value - zero_load_value) * scaling) , assuming that the load cell works reasonable linear. The methods tare(), set_offset() and set_scale() are provided for that purpose.
You might have to use different value for different temperatures.
