ADS1115 16 bit ADC on ESP8266?
weldeng
Post by weldeng » Tue Nov 29, 2016 5:43 pm
I was wondering if anyone has this working yet? Tips on how to get up and running would be appreciated. Adafruit appears to be hosting a driver under development.
http://micropython-ads1015.readthedocs.io/
Re: ADS1115 16 bit ADC on ESP8266?
Post by deshipu » Tue Nov 29, 2016 9:55 pm
Since I wrote that driver, I can tell you that I tested it and confirm that it works.
weldeng
Post by weldeng » Tue Nov 29, 2016 11:21 pm
deshipu wrote:Since I wrote that driver, I can tell you that I tested it and confirm that it works.
Great, I loaded ads1x15.py to the ESP8266. I have an OLED and the ADC connected. Tried a few lines of Code as follows:
>>> import machine
>>> i2c = machine.I2C(machine.Pin(5), machine.Pin(4))
>>> i2c.scan()
[60, 72]
>>> import ads1x15
File "ads1x15.py", line 5
Where do I go from here?
Post by deshipu » Wed Nov 30, 2016 8:06 pm
How did you load it?
weldeng
Post by weldeng » Wed Nov 30, 2016 11:03 pm
deshipu wrote:How did you load it?
I copied the file ads1x15.py using WebRepl to the ESP8266.
Post by deshipu » Thu Dec 01, 2016 8:28 am
Can you verify it copied correctly by reading it out?
with open("ads1x15.py") as f:
    print(f.read())
weldeng
Post by weldeng » Thu Dec 01, 2016 3:09 pm
deshipu wrote:Can you verify it copied correctly by reading it out?
    print(f.read())
Thanks, here is the result.
WebREPL connected
... print(f.read())
File "<stdin>", line 2, in <module>
MemoryError: memory allocation failed, allocating 15616 bytes
Post by pythoncoder » Thu Dec 01, 2016 5:52 pm
Try reading line by line:
with open('ads1x15.py') as f:
    for line in f:
        print(line, end='')
weldeng
Post by weldeng » Thu Dec 01, 2016 11:45 pm
pythoncoder wrote:Try reading line by line:
    for line in f:
        print(line, end='')
Oops!
The file is in HTML. Copied the micropython file over and it seems to be working fine. I put a solar cell on channel 0 and it reads 13541. Actual voltage is 2.561 Volts. Hooked up channel 2 to VDD (3.3V) and it reads 17571
The gain does not appear to correspond to any of the settings from the ADS1X15 docs.
Thanks to all for the help.
weldeng
Post by weldeng » Fri Dec 02, 2016 12:40 am
deshipu - Nice driver! I have a few questions:
1. After trying various gains it appears the max value when reading a channel is 32767 not 65535?
2. Does the driver support use of more than one ADS 1115 module? I have a single module on address 0x49. I could add up to three more using addresses 0x48 (1001000), 0x4A (1001010), and 0x4B (1001011).
3. Is it possible to set a separate gain for each channel.
