UART issue
technodict
UART issue
Post by technodict » Wed Nov 30, 2016 8:27 am
Hello ,
I am trying to run the following code on the ESP8266 Node MCU board. I have put this code in main.py. The input is being taken from a laptop running Cutecom as a terminal program. The issue is uart.read() doesn’t wait to receive any data from serial (Rx). The Rx and Tx pins are connected to corresponding Tx and Rx of a serial to USB converter.
uart = UART(0, 9600, timeout=0)
uart.init(9600, bits=8, parity=None, stop=1)
text = uart.read(12)
if text == b' RECEIVEDTEXT':
uart.write("sucess")
uart.write("failed")
break
platforma
Re: UART issue
Post by platforma » Wed Nov 30, 2016 10:02 am
technodict wrote:The Rx and Tx pins are connected to corresponding Rx and Tx of a serial to USB converter.
Those need to be crossed, i.e:
Board -> |Rx - Tx| <- Usb2Serial
         |Tx - Rx|
You might already have them that way, just though I'll double check!
Re: UART issue
Post by dhylands » Wed Nov 30, 2016 5:11 pm
And also make sure you connect GND from the 8266 to GND on the usb-to-serial converter.
technodict
Re: UART issue
Post by technodict » Thu Dec 01, 2016 5:11 am
Yes the Pins are Rx-Tx Tx-Rx and yes grounds are connected !
Neil
Re: UART issue
Post by Neil » Thu Dec 01, 2016 8:25 am
I think the problem is that the UART.read is not a blocking read and will read the buffer UPTO but not neccessary the exact number of bytes specified. Therefore something like this may work.
text=''
while len(text)<12:
	text += uart.read(1)
note this code is untested and just from the top of my head.
