How-to: Using MQTT with Adafruit.IO and Thingspeak
Posted: Fri Dec 09, 2016 10:11 pm
by Mike Teachman
I've been learning how to use MQTT with two free hobbyist cloud data services. The MQTT protocol is supported in a built-in library in the Micropython binaries -- this protocol can be used send data from your ESP8266, over WIFI, to a free cloud database. For example, your ESP board could read an I2C temperature sensor every minute, then send the data to a cloud database, connecting via WiFi. Then, the cloud stored data can be plotted on a dashboard and viewed using any web browser. The two databases that I have worked with so far are:
1. Adafruit.io https://io.adafruit.com/
2. Thingspeak https://thingspeak.com/
In case anyone can take advantage of this project, I posted the Python code to Github. The code shows:
1. connecting to a WiFi network
2. connecting to the cloud data service using MQTT protocol
3. reading a temperature sensor via I2C
4. reading the number of free bytes in the micropython heap
5. sending the temperature and heap values to a cloud data service using MQTT
6. repeat steps 4 and 5 with a configurable period (e.g. every 30s)
There is a Github repository for each db implementation:
Adafruit: https://github.com/MikeTeachman/micropy ... tt-esp8266
Thingspeak: https://github.com/MikeTeachman/micropy ... tt-esp8266
Please post here if you have any questions, or suggestions.
Re: How-to: Using MQTT with Adafruit.IO and Thingspeak
Posted: Mon Dec 12, 2016 10:49 am
by platforma
Very informative, I was going to try adafruit io at some point, thanks for sharing this!
Posted: Fri Dec 16, 2016 1:39 am
by weldeng
Thanks for posting. I am trying the thingspeak version and not having much luck. Entering line by line in WebRepl to see where the problem might be I get the first error as follows:
>>> from umqtt.simple import MQTTClient
ImportError: cannot import name MQTTClient
Any suggestions on what I am doing wrong?
Posted: Fri Dec 16, 2016 6:50 pm
by Mike Teachman
One thought -- is your ESP running a micropython binary release that includes the MQTT library?
I have used MQTT with two binaries, where the MQTT library is built-in:
esp8266-20160909-v1.8.4.bin
esp8266-20161110-v1.8.6.bin
Posted: Sat Dec 17, 2016 2:22 am
by weldeng
Mike Teachman wrote:One thought -- is your ESP running a micropython binary release that includes the MQTT library?
I am running esp8266-20161017-v1.8.5.bin I will flash with esp8266-20161110-v1.8.6.bin on a different board and try again
Posted: Sat Dec 17, 2016 3:16 am
by Mike Teachman
I downloaded and installed the binary version you are using and tried it. For some reason I can't reproduce the issue that you see. It looks OK on my Feather Huzzah both from the REPL and WebREPL
WebREPL daemon started on ws://192.168.4.1:8266
WebREPL daemon started on ws://0.0.0.0:8266
Started webrepl in normal mode
could not open file 'main.py' for reading
MicroPython v1.8.5-10-g0e69e6b on 2016-10-17; ESP module with ESP8266
>>> dir(MQTTClient)
['set_last_will', '_recv_len', 'ping', '__qualname__', 'subscribe', '__init__', 'set_callback', 'disconnect', '_send_str', 'connect', 'publish', 'wait_msg', '__module__', 'check_msg']
Sorry ! I don't have any other ideas at this time. Hopefully other expert debuggers will read this and offer suggestions...
Posted: Sat Dec 17, 2016 3:48 am
by weldeng
[quote="Mike Teachman"]
>>> dir(MQTTClient)
>>>[/code]
I flashed a different board with v1.8.6 and got the same results as you above. I may have a hardware issue with my other board. Will mess with it some more this weekend. Thanks
Posted: Sat Dec 17, 2016 4:13 pm
by weldeng
weldeng wrote:[
Mike
The other board fixed the issue. I was able to read a couple channels off an ADC1115 ADC and publish to Thingspeak. I never would have figured this MQTT stuff out without your work. Thanks again!!
Posted: Sun Dec 10, 2017 9:37 pm
by Mike Teachman
I updated the example code for using MQTT with the Thingspeak service:
  • added Subscribe example code. Thinkspeak added support for MQTT Subscribe in Nov 2017
  • updated Publish example code to become current with the latest Micropython release
  • removed I2C sensor references from example code. This allows example code to be run with no added hardware.
  • improved the repo notes
