Pin Toggle Performance
rosenrot
Post by rosenrot » Mon Dec 12, 2016 9:41 pm
Hi everyone,
could someone tell me how to toggle the 0 pin the fastest way? I found this post, but it is mostly talking about the STM uC. Maybe someone could tell me how to switch the 0 pin as fast as possible. Maybe with the help of ASM commands?
http://www.mikrocontroller.net/topic/388161
Thanks,
rose
ernitron
Re: Pin Toggle Performance
Post by ernitron » Tue Dec 13, 2016 7:35 pm
Check the topic on sound in here and the reply of pythoncoder. There was a contest on how fast a pin could be set. I am on my mobile and cannot get the link but you can easily find there.
Edit: found
http://forum.micropython.org/viewtopic.php?f=2&t=1349
rosenrot
Post by rosenrot » Tue Dec 13, 2016 7:46 pm
Thanks a lot!
Post by Roberthh » Tue Dec 13, 2016 8:06 pm
These two links circle around the same contest. More recent for the ESP8266 is the following discussion, even if the title is misleading:
http://forum.micropython.org/viewtopic.php?f=16&t=2678
The answer would be like 21.8 us for a full cycle at 80 MHz, using the native code emitter, with something like:
@micropython.native
def toggle():
    pdsckPin = machine.Pin(4, machine.Pin.OUT, value=0)
    isr = machine.disable_irq()
    for i in range(24):
        pdsckPin.value(1)
        pdsckPin.value(0)
    machine.enable_irq(isr)
Using viper code & direct port access should be much faster.
rosenrot
Post by rosenrot » Tue Dec 13, 2016 10:04 pm
Good, that sounds like there is the possibility to get a full cycle of 250ns. I will try this. Thanks again for linking me further!
Post by Roberthh » Wed Dec 14, 2016 6:24 am
It's 21.8 µs for each of the 24 cycles, not for all 24 cycles, and the first cycle always takes longer.
jms
Post by jms » Fri Dec 16, 2016 1:20 pm
Since Micropython on this platform executes not much faster than BASIC on a BBC Micro if you want sub 1uS you'll need to write it in C. You could cheat and pretend it's an SPI device and clock out something using that.
Jon
Post by Roberthh » Sat Dec 17, 2016 3:18 pm
Using viper code and direct register access, you can get a "little bit" faster. The following code example creates a 100 pulse burst with a time of 376 ns between two pulses (or 2.66 MHz) at 80 MHz clock frequency. Using C code or assembler would be a little bit faster
def toggle():
    do_toggle()
@micropython.viper
def do_toggle():
    GPIO_OUT = ptr32(0x60000300) # GPIO base register
    for i in range(100):
        GPIO_OUT[1] = 0x10 # set bit 4
        GPIO_OUT[2] = 0x10 # clear bit 4
Unrolling the loop results in a period duration of 150ns @ 80MHz.
Update: Setting the CPU clock to 160 MHz does NOT increase the toggle frequency.
poesel
Post by poesel » Sun Jun 21, 2020 10:30 am
Sorry to dig this up.
I failed to find any documentation on this part:
Is there documentation or is it obsolete by now?
