I'm trying to install the micropython on the Wemos D1 mini Pro - ESP8266.
So I'm follwing the installation guide on this git => https://github.com/pfalcon/esp-open-sdk
In the part where I need to clone the git to the virtual disk I get error trying to make the build.
Following errors: a copy of the wemos forum where I started the installation ( the cloning didn't work with the link from the wemos forum)
[code]
I used the github link in the github instruction and it worked. After that the make gave me this error
fatal: destination path 'esp-open-sdk' already exists and is not an empty directory.
So.. I cd into the eps-open-sdk and did make again, this gave me this error.
configure: error: missing required tool: help2man
make[1]: *** [_ct-ng] Error 1
make: *** [crosstool-NG/ct-ng] Error 2
Following make clean did this
make: *** No rule to make target `clean'. Stop.
make: *** [clean] Error 2
[/code]
What can I do to get past this, should I restart the installation from scratch and if so how do I rm safely.
MicroPython Wemos D1 mini - ESP8266 installation problems
Re: MicroPython Wemos D1 mini - ESP8266 installation problems
As the error suggest, you need to install help2man, it is listed in the dependencies on the esp-open-sdk page. This should be available in your distro repository.blckpstv wrote: configure: error: missing required tool: help2man
