AttributeError: type object 'socket' has no attribute 'timeout'
jeancf
Post by jeancf » Wed Jan 04, 2017 7:41 pm
I am running micropython 1.8.6 on a Wemos D1 mini v1.
I have an application that uses UDP sockets. It runs but I have a problem catching `timeout` exceptions. This code:
import socket
uart = UART(0, 115200)
s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
s.settimeout(2.0)
s.bind(("", 9999))
    s.receive(10)
except socket.timeout:
    uart.write("Exception caught\n")
throws:
  File "main.py", line 12, in <module>
Instead of catching the exception.
Am I doing something wrong?
ernitron
Re: AttributeError: type object 'socket' has no attribute 'timeout'
Post by ernitron » Wed Jan 04, 2017 8:55 pm
jeancf wrote: Am I doing something wrong?
No I guess, not. I had the same problem. Looks like socket.timeout is not implemented (or is not the correct exception that upython throws on timeout). I simply catch everything and that worked for me.
s.settimeout(2.0)
s.bind(("", 9999))
    s.receive(10)
except:
jeancf
Post by jeancf » Sat Jan 07, 2017 10:07 am
Thanks for the workaround. I can use it for now. I will file a bug.
/~JC
jeancf
Post by jeancf » Tue Jan 17, 2017 2:50 pm
